headlights and dash lights dim and brighten
at night when i have my headlights on they'll dim and brighten along with my dash light and i was thinking that it might be that the alternator is going bad if not already close to junk. i was just looking for some input
thanks
thanks
Re: headlights and dash lights dim and brighten (89CRX89)
My gauge cluster lights and headlights did the same thing, but only at very low RPM (less than 800, I adjusted my idlea tad higher and that helped eliminate the problem). My permanent solution was a new alternator, but I am sure there is another more technical explanation why and how to fix it.
Re: headlights and dash lights dim and brighten (VegasEFHB)
If it isn't RPM sensative, I'd lay my bet on it being the headlight switch on the steering column.
Wes
Wes
Re: (Kryogen)
isnt another problem for this being the ground wires for the breaks.
my dash lights and headlights dim when dropping to low RPM at idle
but also if i use my breaks they dim. i was told its the ground wires for the break lights causing the problem.
i dont know for sure but thats what ive been told
kerubin
08-21-2012 09:26 AM
BLU BY U
09-26-2006 07:39 PM
ArizSun21
02-04-2004 06:14 PM
VTEC
07-02-2002 12:37 PM
