Hazards/ Signals
Old 01-05-2015, 11:35 PM
Justin Meiring's Avatar
Default Hazards/ Signals
The hazards in my 91 civic dx are not working. All bulbs are brand new, and all turn signals work. except the rear passenger side. When i hit the switch, nothing happens. No clicking. The front passenger turn signals flash quickly indicating a bad bulb, but all bulbs are brand new. (I have also switch drivers side bulb to passenger side and the same thing happens.) Could this be a relay, or should i cut the wiring to that turn signal and get a new wiring assembly for it? It looks like it has been messed with quick a bit, lots of electrical tape.
Old 01-06-2015, 12:33 PM
Fosterryan's Avatar
Default Re: Hazards/ Signals
Maybe check your fuses? I had this problem and it turns out I left a wire exposed in my stereo which grounded out on metal and blew my hazards fuse.
Old 01-06-2015, 12:44 PM
ProjetEF's Avatar
it sound like a bad ground
verify continuity between the black wire and the body (pin your tester in the turn signal connector)
if there is no continuity, ground is bad
hybridnorth
37
02-16-2019 06:13 AM
jacreech777
Lighting
08-05-2016 02:27 PM
superfly23
Honda CR-V & Element
02-22-2016 01:00 PM
92civicGA
03-02-2007 10:22 AM
si90rex
08-10-2006 09:54 AM
Quick Reply: Hazards/ Signals
