exhaust silencer
Old 09-30-2009, 03:20 PM
thecorey's Avatar
Default exhaust silencer
i just bought this exhaust silencer on ebay. and it fits fine, but it doesn't make my exhaust much quieter. is there any modifications i can make to the silencer to make it work a little better?
Old 09-30-2009, 04:30 PM
CRX=MC2's Avatar
Default Re: exhaust silencer
DO THIS!!!!
Old 09-30-2009, 04:37 PM
D16SiHatch's Avatar
assuming the piece does fit snug in your exhaust then the idea posted above will work really well for quieting it down.
Old 09-30-2009, 05:56 PM
TunerN00b's Avatar
That mod would make the tip similar to these:
http://www.pacesetterexhaust.com/tips.htm
Except they're using fiberglass instead of steel wool.
The general idea does work. The size of the holes will determine what frequency range is muffled.
Old 09-30-2009, 05:59 PM
Who the fack changed my title?!
sh!ft's Avatar
fiberglass sutch as the same kind of **** up in our attic's? lol
Old 09-30-2009, 08:46 PM
Berkut99's Avatar
Glasspacks have been a standard for performance exhausts for decades; the fiberglass muffles the sound enough to keep it legally quiet but come as close to a straight pipe as possible. I'm surprised you've never heard of it before. Low quality ones sound terrible, though.
Old 09-30-2009, 09:35 PM
Radim's Avatar
Run a catalytic, OEM Exhaust Manifold, and a Resonator.
or better yet get a proper exhaust, not a fart can.
Old 10-01-2009, 02:46 PM
TunerN00b's Avatar
Yup. I have a 30 year old car with 16 year old glasspacks on it. Sounds the same today as it did when I installed the exhaust. As long as you don't get the "muffler" too hot, the fiberglass stays fine. They're little more than a fiberglass packed resonator.
However, if you place a glasspack directly after the header collector or cat, the heat can blow the fiberglass out, and you end up with an empty echo chamber. Sure looks cool as flaming fiberglass comes flying out of the exhaust tip under a WOT pull though...
Old 10-05-2009, 01:19 PM
thecorey's Avatar
Originally Posted by CRX=MC2
DO THIS!!!!
ok....here's what i did. redbull can filled with steel wool. SUPER GHETTO!!...i know. but it works..it's really quiet now. i put a ton of holes in the redbull can. i would have drilled holes in the exhaust silencer itself, but my drill isn't strong enough to drill through it..it's pretty thick steel..i could only manage a couple of holes in it for the screws that hold the can on.
my question is.. do you guys think this is too restrictive on my exhaust? my exhaust is straight through all the way back to the muffler. i don't have a CAT...i just have a resonator where the cat would normally be. so this silencer is the only restriction.
Old 10-05-2009, 02:40 PM
ryanevansoh's Avatar
haha damn that is ghetto as hell! but hey it does the job
Old 10-05-2009, 05:45 PM
thecorey's Avatar
yeah...looks like i'm gonna have to get a new can and reduce the amount of holes or something...it's STILL too loud. i duno...maybe more steel wool too.
does anyone know if it can do any major damage if there i'm causing too much backpressure? i'm not even sure if i'm causing too much...just curious
Old 10-05-2009, 05:46 PM
Pirate General...YARRRR
Ass$nyper's Avatar
I am about to c4 my honda because of this one
Old 10-05-2009, 05:55 PM
pyork03's Avatar
LOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLO LOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLO LOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLO LOLOLOLOLOLOLOLOLOLOLOLOLOLOL
Old 10-05-2009, 06:26 PM
Daisy... Daisy...
Dogginator's Avatar
OP, what the hell? Get a resonator.
Old 10-05-2009, 06:28 PM
Radim's Avatar
Your car is going to be loud no matter what if it's a straight pipe, ***** probably raspy as hell.
Like i said just get a proper exhaust, don't try to run a straight exhaust if it's not a track car.
Old 10-05-2009, 08:00 PM
dacrxguy's Avatar
speechless
Old 10-05-2009, 08:41 PM
Touching My Member
.Manny.'s Avatar
Old 10-05-2009, 08:45 PM
BiG ChOr!Zo's Avatar
that looks tight...you should mass produce them babies and make some easy cheddar
Old 10-05-2009, 09:18 PM
thecorey's Avatar
it is a track car. i just wanna quiet it down for when i occasionally drive it around town.
hence me not wanting to spend a lot of money on a full exhaust. thanks for the attitude though...it really helps my situation! you guys are so helpful!
Old 10-05-2009, 09:27 PM
Radim's Avatar
It's technically not a "track car" if it driven on the streets.
Seriously, no matter what a straight exhaust is going to be loud as ****, i have a way better solution for you one you might even take me up on.... invest in a Electric Cut-out for your exhaust get a nice name brand one though, no ebay crap because they tend to leak.... run a nice exhaust for the streets, open it up for the track.
http://www.jegs.com/p/JEGS/JEGS-Elec...31909/10002/-1
Old 10-06-2009, 08:36 AM
thecorey's Avatar
good call...i'm not that lazy though. i'll just get this one. it's only 25 bucks
Old 10-06-2009, 05:54 PM
beansandrice's Avatar
HOLY F-N SHT, BATMAN!
I think you may need one of these. And leave the Red-bull, It gives you wings.
http://www.summitracing.com/parts/DTC-72-32540/#
Manlion
03-14-2010 07:32 PM
adammartini
Honda S2000
05-07-2009 12:10 PM
Mistermark
18
03-05-2006 01:41 PM
TunerN00b
Welding / Fabrication
08-03-2005 05:10 PM
Quick Reply: exhaust silencer
