GSR leathers in an EF
Old 03-19-2010, 07:45 PM
90civicstdgold's Avatar
Default GSR leathers in an EF
So I have searched for the writeup. In the FAQ it shows them hacking the integra seats and the finished product has a few holes in it. Im wondering if its possible to do anything different?
I think a seat pan swap may be possible but Im not sure. Input from somebody who has done this please chime in. I just dont wanna have to hack up a perfect pair of GSR leathers...
Thanks to whomever replies...
Old 03-19-2010, 08:44 PM
Clipsed's Avatar
Default Re: GSR leathers in an EF
no way without holes without welding
Old 03-20-2010, 08:06 AM
OK.. Is there a company out there that makes rails for them to fit???.. By the way I pulled them from an eg if that matters?
Old 03-20-2010, 09:56 AM
Clipsed's Avatar
no, it's all custom.
Old 03-20-2010, 04:07 PM
efjones9's Avatar
Actually. If u have a 90-91 civic and the seats has eg rails can fit in without welding . Just expand the rear boltster holes half inch. And they fit. Only problem is that they tilt inward just a lil bit
Old 03-22-2010, 06:51 AM
The seats went in with little modification. What I did was expand the holes that the bolts go through a little bit. I made them almost an oval shape and used bigger washers to make sure that nothing could slip or something. The seats originally came from an eg so I already had the rails. I can post pictures later if someone would like to see them?
Old 03-22-2010, 08:03 AM
Clipsed's Avatar
It works, you just gotta do a pan swap, and some welding if you dont want holes...
Here is the only pic I have showing the lumbar support still operational...
It's very simple, the welding is done to keep the lumbar support of the Teg seat, if you don't care about it, and a hole on the bolster, then a pan swap is simple and doable...
Danthemagicbum
03-02-2010 10:01 PM
EvoMperor
09-22-2009 10:48 PM
91 luder
03-09-2009 10:14 AM
RMXmitch
18
12-05-2006 03:12 PM
projecthybrid04
03-22-2003 11:00 AM
Quick Reply: GSR leathers in an EF
