GSR Cluster into 91 Std EF Hatch: Wiring Questions
Alright guys, I hate to post this with so many threads about it and the fact its been covered before but I am needing input on some things so I am turning to you EF guys.
Just recently purchased a GSR cluster for my 91 EF hatch and got some cluster plugs in the mail I purchased off of here the other day from a member. Below is what I posted in another thread:
Your input is appreciated. TIA guys!
Got the cluster plugs in the mail over the weekend. After reviewing a couple of pages back and another website, I am finding I have some wires in different places and needing someone to confirm I am right here: The ones that are highlighted GREEN are the wires in question on the cluster plugs I have.
16pin plug looking at plug plugged into cluster from left to right:
1 - red/blue
2 - light green/red
3- yel/white
4 - blue/white
5- empty
6- orange
7 - green (double silver ticks)
8 - blue/red
9 - red
10 - red/black
11 - black/yellow
12 - empty
13 - green (single silver ticks)
14 - green/yellow
15 - red/green
16 - green/red
13pin plug again left to right:
1 - empty
2- pink
3 - empty
4- yellow
5 - red/blue
6 - black
7 - yellow/green
8 - empty
9 - white/blue
10 - empty
11 - yellow/red
12 - green/orange
13 - blue
This coming from HOW TO INSTALL AN ACURA INTEGRA GsR/TYPE-R GAUGE CLUSTER Into a 90-91 civic/crx
Reading DC plug wire - Function - EF Plug wire
16p
B1 Red/Blue - Fuel gauge - C710 #3 Yellow/white
B2 empty
B3 Yellow/Black - Seat belt light - Empty
B4 Green/Yellow - Low fuel light Not used unless you use a 90-93 integra fuel level guage
B5 empty
B6 Orange - Speedometer Splice in with signal from vss in the tranny
B7 Blue/Black - Trunk/hatch open - C710 #5 Green/Black
B8 empty
B9 Red - Brightness - C709 #9 Red/Black
B10 Red/Black - Gauge lights - C709 #8 Red
B11 Black/White (color varies) - VSS Run the electronic Vss to here and also attach to the orange where b6 is ran..
B12 empty
B13 Green/Red-1 Silver Stripe - Left turn signal - C709 #12 Green/Blue
B14 Green/Yellow-1 Silver Stripe - Right turn signal - C710 #1 Green/Yellow
B15 Red/Green - n/a not used
B16 Green/Red - Emergency brake - C709 #6 Green/Red
13P
C1 empty
C2 empty
C3 empty
C4 Yellow - Dimmer - C710 #2 Black/Yellow
C5 empty - Cruise control - empty
C6 empty - Empty - empty
C7 Black - Black Ground - C710 #8 Black
C8 Yellow/green - Brightness - C709 #10 Yellow/Green
C9 White/Blue - Battery - C709 #2 White/Blue
C10 empty
C11 Yellow/Red - Oil pressure - C709 #5 Yellow/Red
C12 Green/Orange - Check engine - C709 #4 Green/Org
C13 Blue - Tachometer - C710 #2 Blue
Sorry for the long post. Just looking to get things in order to simplify the install.
TIA guys!
1 - red/blue
2 - light green/red
3- yel/white
4 - blue/white
5- empty
6- orange
8 - blue/red
9 - red
10 - red/black
11 - black/yellow
12 - empty
14 - green/yellow
15 - red/green
16 - green/red
1 - empty
2- pink
3 - empty
4- yellow
5 - red/blue
6 - black
7 - yellow/green
8 - empty
9 - white/blue
10 - empty
11 - yellow/red
12 - green/orange
13 - blue
16p
B2 empty
B5 empty
B8 empty
B12 empty
13P
C1 empty
C2 empty
C3 empty
C10 empty
TIA guys!
Re: GSR Cluster into 91 Std EF Hatch: Wiring Questions
Yes sir, I have that layout and I thank you for posting it here for me.
The one I posted is concentrated on pin location while yours is focused on wire color. Which is the correct route to go?
Thanks again for your help!
itr1235
03-16-2006 01:52 PM
