groaning noise at steering wheel - Honda-Tech
Old 10-15-2002, 08:54 AM   #1
SiR831's Avatar
Default groaning noise at steering wheel
i have a 91 Si hatch with B16a (Hasport motor mounts) dropped on some Skunks. I noticed when i adjust the ride height to max low. That the steering wheel makes a groaning noise when turning slightly. It seems like the noise is tranfering from the steering rack to the column then to the steering wheel. Anyone also experience this scenerio and what is the remedy? Thanks!
SiR831 is offline   Reply With Quote
Old 10-15-2002, 10:05 AM   #2
altoid's Avatar
Default Re: groaning noise at steering wheel (SiR831)
probably rubbing against the wheel wells or something of that sort, or if you fully depress your clutch and let your car goto idle rpms when it happens, it could be the power steering taking its toll on the low rpms, almost stalling the car out
altoid is offline   Reply With Quote
95 Civic - groaning/rubbing noise when braking at low speeds Mastermind8 Honda Civic / Del Sol (1992 - 2000) 1 04-06-2015 08:59 PM
Power Steering Noise? help me sky9 Honda Accord (1990 - 2002) 11 02-25-2011 03:40 PM
creaking noise from brakes when slowing down bhed-w Honda Civic / Del Sol (1992 - 2000) 3 12-07-2006 12:12 AM
bad power steering pump? ktwanky Acura RSX DC5 & Honda Civic EP3 3 10-30-2006 06:13 PM
groaning brake noise tsdenny Honda Accord (1990 - 2002) 8 10-01-2005 07:49 AM
Tags
civic, column, crx, ef, groan, groaning, honda, idle, makes, noise, noises, steering, streering, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
