good place to hide a kill switch... - Honda-Tech
Old 10-18-2007, 10:22 PM   #1
MIXINinthe805's Avatar
Default good place to hide a kill switch...
what do you guys think?
MIXINinthe805 is offline   Reply With Quote
Old 10-18-2007, 10:32 PM   #2
denraweb's Avatar
Default Re: good place to hide a kill switch... (MIXINinthe805)
Rather not say? lol
Use your imagination...
denraweb is offline   Reply With Quote
Old 10-18-2007, 11:12 PM   #3
Right on the steering wheel, make sure you put a sticker under it that says " Kill Switch" so you and others dont forget
j/p, put it somewhere you think no one will notice and thieves wont think it will be there.
AKA under a seat or behind your Cd player. Its your call
gourley is offline   Reply With Quote
Old 10-19-2007, 12:09 AM   #4
Foxcow's Avatar
Default Re: good place to hide a kill switch... (gourley)
what would you put the kill switch on? Power for the fuel pump or battery power? Ignition? I really don't know.
Foxcow is offline   Reply With Quote
Old 10-19-2007, 12:21 AM   #5
ef dino's Avatar
Default Re: good place to hide a kill switch... (Foxcow)
Its all up to you man. No ones gonna give out there hiding spots. Be creative, make a fuel cut switch somewhere and an ignition cut somewhere else. And if you wanna go all out make switches for every damn thing in the car. You can make a switch to control your mothers ******* just be creative with where your putting these switches. Your car, your switches. Hide em good!
My buddys got a setup where you have to hold the cigarette lighter down then push the ac button.. You can do WHATEVER you want. If you have an idea and want directions on how to wire it pm me ill give you a very detailed way of how to wire anything you want. hope that helps a bit
ef dino is offline   Reply With Quote
Old 10-19-2007, 12:47 AM   #6
JKGONZALEZ3's Avatar
Default Re: good place to hide a kill switch... (ef dino)
ill tell you mine cause you never get mine started even though i told you were its at. for one of them you have to press the defroster button and wait a certain amount of time before you crank the motor or else it wont crank.
JKGONZALEZ3 is offline   Reply With Quote
Old 10-19-2007, 06:47 AM   #7
onenonly009's Avatar
Default Re: good place to hide a kill switch... (JKGONZALEZ3)
you should make it so u need 2 people to turn a special key at the same time
onenonly009 is offline   Reply With Quote
Old 10-19-2007, 08:45 AM   #8
p nut's Avatar
Go Transporter style and get an ignition code keypad system.
p nut is offline   Reply With Quote
Old 10-19-2007, 09:02 AM   #9
KickStart2323's Avatar
Quote:
can i ask how you did that?...so dose the defroster still work or is it a fake button for the killswitch?
KickStart2323 is offline   Reply With Quote
Old 10-19-2007, 09:47 AM   #10
jdm Ef-9's Avatar
Default Re: good place to hide a kill switch... (KickStart2323)
got mine @ the ac button...sleeeeeeeper
jdm Ef-9 is offline   Reply With Quote
Old 10-19-2007, 10:04 AM   #11
ef9robert's Avatar
i like this :-)
ef9robert is offline   Reply With Quote
Old 10-19-2007, 10:05 AM   #12
EL Vap133's Avatar
Default Re: good place to hide a kill switch... (jdm Ef-9)
Quote:
Unless the thief breaks in on a hot/warm day.
EL Vap133 is offline   Reply With Quote
Old 10-19-2007, 10:16 AM   #13
traxxasx's Avatar
Mines the ciggerette lighter..BAHAHA you cant start it without the ciggerette lighter pushed in....
Im sure noone has this or even knows..well now they do owell..
AHha better have a ecu with you 2.
traxxasx is offline   Reply With Quote
Old 10-19-2007, 10:21 AM   #14
JG90CRX-Si's Avatar
Default Re: good place to hide a kill switch... (EL Vap133)
I did mine a while back and although I won't give the location, I have to turn into a pretzel to turn it off/on. Sometimes I forget it's on and crank the ignition and in a second or two the car turns off.
It's in a great place that's not visible and still easily missed with a flash light.
Thanks H-T for the great write up.
JG
JG90CRX-Si is offline   Reply With Quote
Old 10-19-2007, 04:39 PM   #15
its gonna be on the fuel pump. i had a friend rig it up to the ignition, than it fried his harness, so i figured i'll call that one skip.
someone else i met had a magnet switch in his dash. you just put it next to the panel to get it started, but i haven't been able to find anything like that, or even a specail key switch for that matter
Old 10-19-2007, 04:51 PM   #16
ITR640's Avatar
I dont have one but....
I like the idea of using a preexistinf switch or button. YOu could even get a foglight switch or cruise switch and use it to be your kill switch.
Or maybe that button that makes that little JDM parking pole thing work and use it as a kill switch.
ITR640 is offline   Reply With Quote
Old 10-19-2007, 05:12 PM   #17
tougetuned_ef's Avatar
Default Re: (ITR640)
i heard one time of a guy rigged up a click pen in his ceter console so you have to click the pen once to start the car. i know that if was to try to steal a car i wouldnt think to click the pen once to start it. jsut think like a car thief and you will come up with something creative. i met a guy at a meet who put on of those key pads in and he said not even 3 days after he put it in someone tried to steal his car and couldnt do it. it was set up so if you try to take the keypad off it would never start.
tougetuned_ef is offline   Reply With Quote
Old 10-19-2007, 05:51 PM   #18
grog's Avatar
Default Re: (tougetuned_ef)
some
Quote:
I've heard of using "home security" switches like for a window, its 2 magnets that when placed together complete the switch. so you hide one of the magnets behind something, dash,carpet, or anywhere . to "flip the switch" you stick the other magnet there. when you park take the magnet with you
I believe there are some security write ups if you search, much more detailed than the above
grog is offline   Reply With Quote
Old 10-19-2007, 06:16 PM   #19
KrenzyRyan's Avatar
Quote:
Thats just weird
KrenzyRyan is offline   Reply With Quote
Old 10-19-2007, 06:24 PM   #20
Torque Junkie
Trakhor's Avatar
If I told you I'd have to "kill" you.
General rule of thumb is put it in plain sight but not obvious.
I knew a guy who rigged up a relay to his "power antenna" feed on his radio. He turned the key on then the radio, then he could start.
Trakhor is offline   Reply With Quote
Old 10-24-2007, 04:51 PM   #21
Default Re: (grog)
the home security peice souunds like it makes more sense. would something like that wire up with a 12 volt system though?
Old 10-24-2007, 05:33 PM   #22
Tippyman's Avatar
Default Re: (MIXINinthe805)
If it can handle house voltage, it can certainly handle 12v.
Tippyman is offline   Reply With Quote
Old 10-24-2007, 05:50 PM   #23
Fuzzy Rhubarb's Avatar
Sounds like a job for some Microchip PICS.
Fuzzy Rhubarb is offline   Reply With Quote
Old 10-24-2007, 06:20 PM   #24
Wes V's Avatar
Default Re: (Fuzzy Rhubarb)
Here is a link to a page that shows hiding a magnetic reed switch;
http://www.performanceforum.com/bob/bob6/bob6.html
Wes
Wes V is offline   Reply With Quote
Old 10-24-2007, 06:22 PM   #25
Default Re: (Wes V)
Wire up a fingerprint reader.
Delete OmarR For Sale 0 02-09-2016 07:16 AM
AZ ... OneSlowEkHatch Vehicles for sale 0 10-16-2015 07:09 AM
------------------------ thaijdmpart For Sale 0 11-20-2014 12:37 AM
civic trade battmancjz Southern California (Sales) 15 03-06-2014 10:41 AM
WOW!!!!!! Newborn_ Acura NSX 3 06-17-2006 12:31 PM
Tags
92, air, car, civic, conditioner, good, hide, honda, jdm, keypad, kill, killswitch, making, place, places, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
