FUSE BOX HELP! What plugs in???
We are checking out the main fuse box in the engine bay of the 90 CRX HF. Which wires connect to the two screw ports on the left? Right now we have 1 wire spliced into two coming from the battery. Should the wire go from the battery, to the starter, then from the starter to the fuse box? Which colored wires go in the other port next to it? Help!
Where do the red and black wires come from?
Re: (1g)
yes, this would be correct as the wire closer to the outer side of the box is for the battery and the inner wire goes to the alternator. the one for the starter draws straight off the battery itself
Re: FUSE BOX HELP! What plugs in??? (jimihendrixbro)
if that part of the harness hasn't been touched, then it's still there, you will just have to extend it to fit inside where your fuse box has been relocated. if not, then just run some 10ga or larger wire from the alt to the fuse box.
notnic3
06-12-2017 11:26 AM
evilho75
05-13-2012 01:35 PM
DailyDriven259
05-11-2012 11:31 AM
lilo_goki
08-22-2008 03:46 PM
