fuel not pumping
Re: fuel not pumping (pelon 1990 civic si)
i had a problem with my 89 si and found that the ground wire in the back under that hatch cover was bad i just took it off and ground to bare metal and reinstalled it car started right up. i work at a honda dealership in service and it only takes a few minutes. try that and if that doesn't work check the wires at the top of the gas tank they also like to corrode. let me know what happens
Re: fuel not pumping (nuttybumpo)
It was a fuse. First I had check the cover of the fuses and it didnt said nothing about a fuel pump. But i also had no spark. So i took one by one and second from the top was bad chage it and started rite up. thanks for the help.
My_EFsedan
06-30-2009 03:49 PM
alscrx
03-05-2009 03:07 PM
