finding the cooling fan relay??
Old 05-23-2007, 07:37 PM
wens_crx's Avatar
Default finding the cooling fan relay??
anyone know where i can find where the relay goes to coling fan 88 rex
Old 05-23-2007, 09:15 PM
EF_LSVtec's Avatar
Default Re: finding the cooling fan relay?? (wens_crx)
the fan switch is on the radiator housing...you can just trace that wire and it should lead you to the relay...
unless someone here who has a manual that can post the exact location.
Old 05-24-2007, 02:48 AM
Cory man's Avatar
Default Re: finding the cooling fan relay?? (EF_LSVtec)
Its located in front of the air filter box. There are 2 relays there, IIRC one is the a/c clutch relay and the other is the cooling fan relay. They interchange for easy testing.
BTW, the radiator fan switch isnt on the t stat housing on any nonobd d series or b series, its screwed into the back of the block.
Old 05-24-2007, 04:15 PM
wens_crx's Avatar
Default Re: finding the cooling fan relay?? (Cory man)
thanks
Old 05-25-2007, 07:53 AM
jlicrx's Avatar
if you don't have A/C, you have one cooling fan relay which is located on the passenger side inner fender panel behind the battery - if you have A/C, you have 3 relays - one which is the same as if you didn't have A/C and 2 which are for the A/C condenser fan and one for the A/C clutch - these 2 are located on the passenger side end of the radiator support
slickrickauto
05-29-2010 03:01 PM
Jonathan_ED3
09-27-2008 10:11 AM
Run Away
06-07-2008 10:12 AM
Nisif
01-17-2006 03:01 PM
Quick Reply: finding the cooling fan relay??
