Filling new AC sanden TR70 ac compressor with ester oil - Honda-Tech
Old 05-21-2007, 10:25 AM   #1
stegs's Avatar
Default Filling new AC sanden TR70 ac compressor with ester oil
I am finishing up my AC install with the use of the HCP AC bracket fitting the stock (remanned) sanden TR70 compressor. I have the service manual which calls for 4 ounces of compressor oil (ester oil since converting to R-134), but I don't know where to add the oil.
The compressor body doesn't appear to have a fill plug. It has two holes on the top where you hook up the suction and discharge plumbing, and then a relief valve one the side of the housing.
Does anybody know where you dump the oil in before recharging?
stegs is offline   Reply With Quote
Old 05-21-2007, 04:08 PM   #2
Wes V's Avatar
Default Re: Filling new AC sanden TR70 ac compressor with ester oil (stegs)
Remove one of the hose lines and just pour it in.
Wes
Wes V is offline   Reply With Quote
Old 05-21-2007, 07:01 PM   #3
Crx Jimmy's Avatar
Default Re: Filling new AC sanden TR70 ac compressor with ester oil (Wes V)
Quote:
Wes
it just goes in and circulates in the system. it doesnt go in any particular place. why switch to r134 when r12 is still available and gets it much colder than r134 which sucks in my opinion(well on r12 converted units)
Crx Jimmy is offline   Reply With Quote
Old 06-29-2011, 09:27 PM   #4
the compressor has two holes, make sure you add it on the biggest one
93ludefreak is offline   Reply With Quote
Old 06-30-2011, 06:47 AM   #5
Keyboard Humorist
4drEF's Avatar
Quote:
You just replied to a post that is just over 4 years old
4drEF is offline   Reply With Quote
Old 07-01-2011, 12:55 AM   #6
lol. holy shi*. thats funny bro. new to this thing.
Old 07-01-2011, 09:50 AM   #7
OG Hot Rodder
MarkOlson's Avatar
Actually, it was helpful for us. My son and I are about to put a rebuilt Sanden compressor in his project car, and we did not know this.
Just out of curiosity, why should you put it on the larger hole?
MarkOlson is offline   Reply With Quote
Old 07-01-2011, 03:06 PM   #8
Keyboard Humorist
4drEF's Avatar
When turning the compressor by hand, one port creates suction.
While filling with oil you rotate by hand to distribute the oil.
Putting it in the other hole will likely end up shooting some oil out as you rotate.
Old 07-01-2011, 08:44 PM   #9
OG Hot Rodder
MarkOlson's Avatar
Makes sense. Thanks for the explanation.
94 Sanden AC Compressor in CRX JMZ400 Honda CRX / EF Civic (1988 - 1991) 77 04-27-2015 06:41 AM
need pic of a/c compressor and bracket triangle1020 Honda CRX / EF Civic (1988 - 1991) 1 08-04-2009 10:40 AM
Sanden a/c bracket and bypass pulley for EF triangle1020 Want to Buy 1 07-30-2009 07:47 PM
AC compressor - new aftermarket or rebuilt sanden?? steeltoe Honda CRX / EF Civic (1988 - 1991) 8 07-16-2008 02:55 PM
A/C Clutch Oil? all-mtr-teg Tech / Misc 6 03-08-2008 07:11 PM
Tags
2001, ac, civic, compressor, crx, ester, filling, honda, oil, pour, relief, sanden, tr70, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
