Failed e-test, can anyone give suggestions on how to pass?
I took in my b16 ef to get e-tested and it failed, miserably.
the test was a 2 speed idle(too low to get on the dyno) and iut was tested under hot rod specs since it doesn't reatin the stock block. If you can help that would be appreciated...
test results:
IDLE
hc ppm--limit-300 reading-463 fail!
CO % --limit-1.5 reading-2.66 fail!
2500 rpm
hc ppm--limit-300 reading-793 fail!
CO % --limit1.5 reading-6.74 fail!
Can yu help me out?
Thanks
Matt
test results:
IDLE
2500 rpm
Can yu help me out?
Thanks
Matt
Re: Failed e-test, can anyone give suggestions on how to pass? (JDMef_typeR)
same thing happen to me i have a b16a2 motor in my eg hatch back, so i took it to a local import shop and had the mechanic look at it he said get a p30 ecu (theres was a p28 ecu in it) and a new cat converter so i got those and it passed
isnt canada's emmisions really strict? they dont even bother in NY, so my advice is move here
Re: (droppedcrxsi)
lol, what emissions you got there.
In Finland its like this, with B16A1
HC ppm: limit 100
CO %: 1,5 (if i remember right)
But in here, all cars after 92 have to be low- emission (Equipped with catalytic convertor).
But Honda made low emission cars from 89->
And by the way, cat doesent warm up at idle, you have to warm it very long.
HC ppm: limit 100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMef_typeR »</TD></TR><TR><TD CLASS="quote">I took in my b16 ef to get e-tested and it failed, miserably.
test results:
IDLE
2500 rpm
Can yu help me out?
Thanks
Matt</TD></TR></TABLE>
new cat will get you passed almost for sure.
your cat is dead if you failed.
your o2 sensor not functioning properly is almost 99.9% definitely what killed your cat.
a new o2 sensor will make sure you don't kill the new cat.
proper fix: new cat, new o2 sensor, and verify proper ignition timing. You should also replace the cap, rotor, plugs... and ohms the plug wires... and ohms the primary coil while you're at it.
for the love of christ do not go to honda for emissions parts.
honda price for cat: $800
autozone price: <$200
test results:
IDLE
2500 rpm
Can yu help me out?
Thanks
Re: (Twilight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight »</TD></TR><TR><TD CLASS="quote">And by the way, cat doesent warm up at idle, you have to warm it very long.</TD></TR></TABLE>
hmmm.. that's not the way I understand it.
here's a link
http://www.federallabs.org/ser...-Item
third paragraph...
here's a link
third paragraph...
Re: (92integra_gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">i never thought canada having a e-test...</TD></TR></TABLE>
i was wondering that myself..
i mean what's the ******* point..
they don't have a smog problem, and it looks like they're not even testing for NOx anyways.. which means they're not even concerned about developing a smog problem..
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">What about running an alcohol/gas mixture for the E-test.</TD></TR></TABLE>
I'm not too experiences with this.
I'm thinking it could help him pass at idle, because he's only over by 150ppm.
but he's over double the limit at 2500. From what I've heard the alcohol thing can't help more than a couple hundred at most.
can the alcohol thing really help that much?
anyone have any good links about this? not necessarily from h-t, any link will do..
Alcohol is a clean burning fuel...so the emissions on a vehicle running a high % alcohol alcohol/fuel mixture should do surprisingly well on a test.
The only thing is, I'm not sure you can get the stock ECU to deliver enough fuel when running a high % mixture, since you have to burn a LOT more alcohol than fuel. If you had Hondata or some other tuneable ECU, you could easily tune a map specifically for running alcohol. With a tuneable ECU and properly sized injectors/fuel delivery system, you could even run 100% alcohol.
I don't have any sites to support this, but I know big auto manufacturers like GM and Ford have cars that are designated as "Flex-Fuel" and they can run 100% gasoline, 100% alcohol, or anything in between.
Re: (DaX)
With a tuneable ECU also, couldn't he just change out his fuel maps on 100% gas to allow for a leaner burning mixture, retard timing, etc etc therefor negating the need for an alcohol mixture?
Re: (DaX)
yeah I heard that alcohol stoichometric ratio is a lot richer than a regular fuel ratio. Like a race alcohol car runs at something like 8:1, but that would be rich for a clean burn I suppose since they're trying to get power out of it, and not concerned about emissions.
so his ecu would have to find a happy medium between the gas and the alcohol i guess.
also alcohol likes to burn at a higher compression ratio.
so i dunno.
it's a good idea but it might require more work than just fixing it the right way.
I'm sure there's instances where just throwing some alcohol in the gas tank could help you pass.. but what situations would they be.
we need an expert..
so i dunno.
we need an expert..
zzzzzzzz
12
08-02-2008 11:46 AM
hybrider
04-30-2003 12:44 PM
hybrider
04-29-2003 06:50 PM
