Extremly high idle b16a
Old 11-13-2013, 08:09 PM
Glowicki's Avatar
Default Extremly high idle b16a
So, I put a b16a swap into my crx Dx about a month ago. It had a high idle and I was barely able to get it down to 750rpm after it warmed up. My problem now is, the idle screw is adjusted as low as it will go and after the engine warms up, it idles around 2000rpm.
Is my tps at fault? If so, how would I check to see if it is the problem?
Old 11-13-2013, 09:12 PM
Glowicki's Avatar
I may have found what was wrong. I just watched a YouTube video from Eric the car guy on another thread, then another video, then another video, (you all understand how easily distracting YouTube is) and stumbled upon one where he adjusts his throttle cable. It now seems as if my cable is a little too tight. I'll adjust it tomorrow and report back.
Old 11-13-2013, 10:24 PM
jpciii's Avatar
Default Re: Extremly high idle b16a
Clean out or replace the idle air control valve (IACV). Also make sure there are no vacuum leaks.
Old 11-13-2013, 10:33 PM
Ferio Wdm Edition
ferio-ichi3's Avatar
I concur on everything that has been said thus far.
Old 11-14-2013, 04:57 AM
Freemananana's Avatar
Yeah, IACV is likely the cause. Or vacuum leaks. Both are easy to clean/fix. Also look at the FITV if your B16A has one. Eric the Car Guy is pretty good for little things. My B16A idles at about 1500 until it warms up. But 750-850 is fine for a warm idle.
Old 11-14-2013, 05:44 AM
Glowicki's Avatar
I can't seem to find the iacv for fitv on my intake mani. I'll post a pic in a bit.
Old 11-14-2013, 05:48 AM
Ferio Wdm Edition
Iacv is on the back of the manifold, the fitv should be underneath the throttle body.
Old 11-14-2013, 06:02 AM
Glowicki's Avatar
Old 11-14-2013, 07:49 AM
jpciii's Avatar
The IACV is the cylinder shaped thing on the back of the intake mani in your top pic. Its function is to allow some air to bypass the throttle body (basically creating a small controlled vacuum leak) to bump up the idle speed... like when the AC is on, for instance. They can get gunked up inside and want to stick open. That part is on a lot of Hondas. Do a search on cleaning them out. It is a very common pest regarding idle problems.
Old 11-14-2013, 08:12 AM
Furthermore, the FITV should be under the throttle body. That is basically where the intake meets the tube that goes to the air box. Also very common on these hondas and is also very easy to fix.
Old 11-14-2013, 05:44 PM
Glowicki's Avatar
I found a couple write ups on here on how to clean both. I'll have to tackle them this weekend.
Old 11-15-2013, 06:11 AM
zrickety's Avatar
You will probably find the FITV is unscrewed. Screw that puppy all the way in and your idle should drop. If that's not enough, someone may have adjusted the base idle screw on the bottom. There is a whole procedure to set that and the TPS. Good luck.
Old 11-15-2013, 11:02 AM
Glowicki's Avatar
If you could post the process, that would be greatly helpful. I had adjusted about two weeks ago, but it didn't help.
Old 11-17-2013, 05:14 AM
zrickety's Avatar
You will have to search for the procedure, I don't remember the details. You might have a vacuum leak too, have you changed the intake or TB gaskets?
Old 11-17-2013, 05:50 AM
Technical Hero
HondaPartsHero's Avatar
If you've checked for no vacuum leaks follow these in this order (DO NOT adjust the base idle screw):
Clean IACV
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
Clean FITV
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
Adjust throttle cable
http://www.hondacivicforum.com/forum...ed-help-60115/
Adjust idle
http://crxcommunity.com/viewtopic.php?f=4&t=10686
Old 11-17-2013, 10:39 AM
Glowicki's Avatar
Thanks for the info, I'll have to take a look at the car when I get a chance. I should be able to in the next week or so.
Old 02-27-2014, 07:35 AM
Glowicki's Avatar
I know I haven't replied in a while. About a month or so ago I cleaned out the fitv and iacv an that fixed the high idle.
After I drove the hell out of the car to school yesterday, the idle is right back where it was before I cleaned the fitv and iacv.
I'm going to clean them both put again next week. I was just wondering what would cause the idle to jump back up to 3000 rpm when it was 750 rpm the day before.
Old 02-27-2014, 09:32 PM
TeamRedline89Hatch's Avatar
3000 rpm, I'd say vacuum leak.
Check your throttle cable to see if it is too tight also.
Old 02-28-2014, 04:42 AM
Glowicki's Avatar
I'll check for some vacuum leaks when I get a chance. The throttle cable is already adjusted properly.
Old 02-28-2014, 04:56 AM
Fliptard's Avatar
not trying to highjack, but my A6/Z6 idles at 2K as well, cleaned the IACV and that's not the issues, idle screw is all the way it. Have adjusted the cable, and tightened the FITV. Have checked for vacuum leaks with break clean and propane with nothing found.
apbtwhiskey
03-20-2013 09:39 PM
aojtin
12
10-10-2008 06:11 PM
ekb16
04-26-2006 07:47 AM
Irish Integra
03-31-2005 02:30 PM
Quick Reply: Extremly high idle b16a
