every time i press the brake the door ajar light flases an beeps.
every time i press the brake the door ajar light comes on and it is annoying the hell out of me. I checked the fuses they seem okay. And i also need a fender for a 90 crx. HELP
Re: every time i press the brake the door ajar light flases an beeps. (jacobforcecrx)
Check for a short in the wire where your brake light switch circuit is coming in contact with the door switch.
I bet thats irritating. I'd check for a wire grounded out.
Re: every time i press the brake the door ajar light flases an beeps. (Autoworks)
Fixed it! It ended up being the fuse under the hood. I didn't even check those. Thanks for all yhe help i'm still looking for a fender though. Also i now need a new exhaust i backed into a curb and bent mine all to ****.
Re: every time i press the brake the door ajar light flases an beeps. (Magick211)
lett me know i also need the exhaust. Just let me know something. and the drivers side window track.
Brake-Horn fuse 20a under the hood was blown. Popped a new one in and we are good to go.
thank you thank you thank you thank you!!!!!!!
sorry to thread-necromance here but you just helped us solve a two month long problem in about 20 seconds. Lord knows what made the fuse blow but it hasn't happened again.
Does anyone know why that happened to the op? I know the solution was a fuse but if the fuse was for the brake/horn why would it affect the door ajar light?
I've had this issue for the last couple weeks. googled it and found someone with my same car who fixed this issue 12 years ago.
problem solved in under a minute.
Just another reason why I love this forum!
I'm ok with necromancing threads by confirming helpful content like the last two did.
As for why? Probably designed purposely so the driver knows there's an issue so that it's fixed sooner than the risk of driving without brake lights. Just a thought.
CRX T-Si
16
06-23-2006 11:30 PM
Wilky
16
01-24-2006 04:21 PM
