91 crx d15-vtec wont start help
Old 02-20-2011, 02:33 PM
DehKillaBeezz's Avatar
Default 91 crx d15-vtec wont start help
i have a 91 crx si with a d15 v-tec that wont start. i bought it and drove it for a month or two and parked it and went out one day to start it and nothing, it has fuel, it has spark, it cranks, relay works, distributer is good, it has the stock ecu and stock wiring harness..... i think the harness maybe a hack job and a wire may be keeping it from start. any ideas???????
Old 02-20-2011, 02:50 PM
KINGVEM^^ED6's Avatar
Default Re: 91 crx d15-vtec wont start help
if ur harness.is hacked up it could be anything
and u checked all ur grounds???
Old 02-20-2011, 02:51 PM
also any CEL'S
Old 02-20-2011, 02:56 PM
when i was driving the car i got a injector code and a o2 censor code. its a pm6 ecu which means he wired in vtech
Old 02-20-2011, 02:57 PM
i have grounds on head/valve cover, trans, frame
Old 02-20-2011, 03:01 PM
try using another ecu
idk how ur running a pm6
does ur vtec work?
Old 02-20-2011, 03:08 PM
on those swaps then can do jumpers to run vtec and yes it worked when i drove it, i forget what ecu's i can try and test like off my buddies cars, idk if p08 or p28 work with the plugs i have
Old 02-20-2011, 05:46 PM
tobster's Avatar
put a set of jumper cables from the - battery to the grounds on the thermostat housing if that doesnt work you could have a bad dizzy ive had some that would spark but just not enough spark
Old 02-20-2011, 11:48 PM
hatchet_honda's Avatar
is this motor a d15b jdm vtec? cant see how an obd1 engine would run very good with that obd0 ecu
Old 02-20-2011, 11:50 PM
neither of those ecus will plug into your chassis harness unless you have an obd jumperr
Old 02-21-2011, 06:34 AM
lazy14's Avatar
when you checked for spark what color was the spark? i found that white spark is weak, a bluish color is what you want. u should jus need a obd0 single cam ecu out of a civic
Old 02-22-2011, 03:14 PM
yeah i gotta find a obo ecu and the car has more then enough spark trust me.......
Old 02-22-2011, 03:15 PM
i think it is a jdm motor but i maybe wrong, and u can jump wires to make it run right, but its just jerk offs that do it...
Old 02-22-2011, 08:37 PM
well what does the engine block say? d15b? and yeah i guess you can rig shizz to work but why do ppl slaughter hondas like that?? the most idiotic retards try wiring engines and sensors themselves when they can probably barely change a tire ...sorry ive been looking for an eg lately and the ones i find are just hacked up crapboxes
Old 02-28-2011, 07:41 AM
yeah i agree im thinking about doing a swap and being done with it that way i just know everything thats done to it hahaha and its not a mystery
GNRlies411
04-02-2012 01:37 PM
Hype-S
10
01-06-2006 01:57 PM
adler
23
09-26-2004 02:10 AM
detailer67
04-22-2004 08:10 PM
mockujin
11-13-2002 07:03 PM
Quick Reply: 91 crx d15-vtec wont start help
