Emissions and Intermittent Check Engine Light need help
1990 crx dx auto 1.5
So I got the radiator in today and took it for a drive..
Thought I had a leak for a minute but it was from me bleeding the system heh gees anyway...
I have to go through emissions and sometimes i fail it and then a retest i often pass.. but during the emissions test they make you run the car at about 2500RPM for an extended time about 3 minutes maybe..
when i do that sometimes I throw a check engine.
Coming home from the test drive right now i decided to do that and run the car at 2500RPM for a while.. Check Engine came on and I turned the car off...
Forgot to check the computer light for the blink code and then turned the key back to the on position..
Computer is blinking a steady 1 beat every three seconds or so while running.
Check Engine went off when I shutdown and restarted.
I tried running it 2500RPM again for a real long time .. turned my high beams on and no check engine light.
Not sure what it could be
Wondering when the last time i changed the pcv valve .. not even sure exactly where it is so thats an indicator...
anyway i have to cut the grass before it gets dark
if you have any ideas pass them my way.
Re: Emissions and Intermittent Check Engine Light need help
i don't know it just blinks steady once every 3 seconds
i dont know if thats a code or just the computer saying its alive
just finished the grass .. i will look that up if i can find a reference chart
well that was quick the ECU Code for a single blink seems to be O2 sensor
and that would go along with me not passing my emissions test
can you please verify if I am understanding this correctly?
https://honda-tech.com/tech-misc-15/...de%5D-1214478/
thats where I got the code
I am gonna try to find another chart just to be sure
I have a 1990 honda crx base/dx 1.5 automatic
its blinking once every 3 seconds ... about .. i guess heh
yep found another guide and 1 is O2 sensor... its probably the original one .. everything on my car is original ..
I should keep everything I replace on my car thats original
and build another non working crx
so bought a denso O2 sensor today with the connector on it
$24 at Advance Auto but I had a coupon so it came out to like $17
I have a O2 socket i got at harborfreight its 3/8"
fits but its a standard deep socket with a slot
not the kind many people use .. shorty with a side wrench socket
got home
Tried my craftsman 3/8" wrench on it
slipped a steel pipe over the end .. felt like i was about to waste the wrench
went to harborfreight
picked up a 3/8 breaker bar.. just no room for it even with the radiator fan out
also picked up a 1/2" to 3/8" impact adapter
have been spraying the sensor every couple hours with wd40
I can get my gun in there ok with the fan out.
but my compressor is kinda weak.. haven't tried getting it out yet
maybe tonight or tomorrow.
if you need to pickup some parts
advance auto has a $50 off $125 i used on my radiator
Take $50 Off $125 or more with code WD519 at AdvanceAutoParts.com! Valid 5/10 through 5/16. Valid online only.
or $10 off 30 i used on the O2 sensor
Take $10 off $30, $25 off $70 and $40 off $110 orders with code A124 at AdvanceAutoParts.com! Ends 5/31. Valid online only.
got home
ok so ...... replaced the O2 sensor
pulled the battery cable after installing to clear the code
ran ok while warming up I didn't feel any difference really
once I held it at 2500 rpm for about 2 minute maybe less
it threw a check engine and is blinking code 1 again.
I didn't clean anything with carb cleaner.
I didn't drop the o2 sensor
all i used was WD40 getting it off and antiseize (not a lot) putting it on.
not sure if i should go get another o2 sensor .. gonna try to do some more reading on this .. pretty bumbed out that it seems to be worse..
I am going to make sure the connector is clean but I thought it was ok i wiped it out before connecting the new one
ok so this is screwed up
I just went out again .. pulled the connector on the o2 sensor
just to have peace of mind.. its dry and clean
put it back on
run the car at 1500 rpm for 10 minutes until the fan comes on twice
run it up to about 2100 rpm and it check engines with a code 1
then i clear that
for shitsandgiggles I pull the o2 sensor cable at the connector
run the car up to 2500 rpm for a good 4 minutes
NO CHECK ENGINE
I put the cable back on
Run the car for another 4 minutes with the O2 Sensor connected
NO CHECK ENGINE
I got no fricken idea what the.. BLANK is up with this thing...
the no check engine with the O2 sensor disconnected really surprised me
put it back on
then i clear that
NO CHECK ENGINE
NO CHECK ENGINE
Ok so i took the car in for the Emissions Test
I passed
Although i was 10 days late on the registration so i had to pay $10
not sure why thats right for them to do but it is what it is.
as a bonus i think my expiration for my next inspection was moved up 2 weeks
so that gives me more time in the spring .. after taxes and other things that are annual that limit my ability to work on the car before i bring it in. so that might help next time.
What I did to get the inspection done
Replaced the following
radiator
o2 sensor
Air Filter
Gas Cap
every vacuum line i could but most were replaced with fuel line and water hoses because no one sells the right size vacuum lines anymore..
I drove the new O2 sensor for about 75 miles before i brought it in
I think the Vacuum lines helped a lot
other than that i probably got real lucky
didn't install the computer i bought off ebay .. i will keep it for the future because those things are getting scarce
When I tried to find a fuel pressure regulator for it .. no one carries it .. Honda parts guy told me good luck because he can't order one.. I think I still can get one from aftermarket but its $100... I might just get one to keep.
It seems a lot of parts on our CRXs that were OEM are no longer being made.
I don't know what the future leads but it seems its going to be a lot of aftermarket stuff and probably in the next 10 years our cars won't be on the road unless they have engine changes and suspension changes..
My car is totally stock except for the paint and aftermarket generic parts i put on it.
I don't think my state would allow me to make an engine change
I did ask and the only other option is to title it as Antique at 25 years old which my car is but it means you can only drive it to shows so unless I can find shows at every store i need to go to .. yeah .. like that..
anyway that was my experience
probably getting time to think of a new vehicle to buy
i've had this for just over 15 years
probably long enough considering everything
either that or move to one of the 15 states that don't have inspections anymore
maybe i can get a bill passed in my state to end inspections or at least end them for cars over 25 years old..
Statistics say inspection related accidents are not a problem in any state for personal vehicles.. mainly only for tractor trailers and heavy load vehicles that require a Class A or B license.
I passed
radiator
o2 sensor
Air Filter
Gas Cap
EFJDM1
09-23-2016 10:33 PM
