ef rear disc brake swap - Honda-Tech
Old 11-23-2011, 06:19 PM   #1
Icon2 ef rear disc brake swap
need help
am planing on doing a rear disc brake conversion on my civic
but wont to see if i can use a 91 ex proportioning valve i also got the
ex setup for big brake
89civicstd is offline   Reply With Quote
Old 11-23-2011, 06:39 PM   #2
Default Re: ef rear disc brake swap
Check for the "4040" stamp on the prop valve
chris riz is offline   Reply With Quote
Old 11-23-2011, 08:41 PM   #3
I got both the 4040 and the 3540 but I wanna keep my booster and run the 1516 master clyinder
Old 11-24-2011, 02:28 AM   #4
Clipsed's Avatar
need to find an EX mc if you want to keep your booster.
Clipsed is offline   Reply With Quote
Old 11-24-2011, 09:34 AM   #5
Well I got two a 91 ex mc and 90 si mc so it don't matter if I use the 3540 valve
Old 11-24-2011, 09:47 AM   #6
Clipsed's Avatar
you can use the 3540 if you don't want to install the 4040
Old 11-24-2011, 10:03 AM   #7
Quote:
he can but will definitely go thru rear pads fast.
apexi_rsx is offline   Reply With Quote
Old 11-24-2011, 11:19 AM   #8
Doesn't the 3540 valve shoot a bit less fluid then the 4040. Why will waste the rear pads faster
Old 11-24-2011, 12:14 PM   #9
DCRB's Avatar
why would the 3540 wear pads faster? it's sending less pressure to the rears, so technically wouldn't the rears last longer? and the car would be more front biased?
DCRB is offline   Reply With Quote
Old 11-24-2011, 12:43 PM   #10
if I use the 4040 will it lock up my brakes
Old 11-24-2011, 05:50 PM   #11
Clipsed's Avatar
Yes.
Old 11-24-2011, 09:18 PM   #12
So the best way to go is the 3540
Can I use my stock camber arm?
Old 11-24-2011, 11:03 PM   #13
Clipsed's Avatar
You will only use the trailing arm itself, all the arms will need to be from your civic.
integra rear disc brakes? mach0 Honda Civic / Del Sol (1992 - 2000) 3 05-21-2007 08:32 AM
Civic EX with rear drums? GapxGuy Honda Civic / Del Sol (1992 - 2000) 10 05-27-2006 07:18 PM
Rear Discs on EJ1 HBADGE Honda Civic / Del Sol (1992 - 2000) 5 06-04-2005 05:36 PM
rear disc brake project civic Honda Civic / Del Sol (1992 - 2000) 3 02-25-2005 07:55 PM
94 accord rear disc conversion b18bEG Honda Accord (1990 - 2002) 27 08-05-2002 11:38 AM
Tags
89, 90, brake, brakes, civic, conversion, disc, disk, ef, ef9, proportioning, rear, swap, swwap, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
