D16Y8 / D16A6 problems, Please help?!?!?
so a week ago my car was dumping coolant into overflow tank( expanding it until fluid leaks out) and i replaced head gasket over this 3 day weekend and it seemed fine for a day until today wen it started doing that again and my heater going from burning hot too cool.... so im like whats going on. thermostat maybe? i have never replaced it before.... also my car surges idle. any advise is greatly appreciated
Re: D16Y8 / D16A6 problems, Please help?!?!?
you should check your block, my a6 recently over heated and the head is currently off. i plan on taking the block out and getting it checked out and maybe resurfaced. but i was wondering if any of you honda diy wizards know where i could get a headgasket to help compromise for the shaved metal off both the block and head...because wouldnt that increase the compression ratio?? any info will help
i have never over heated it past 3\4 on temp gauge... idk about previous owner but ya... my car ran perfect b4 i took head off but just sent coolant too overflow tank.. i have never replaced or checked thermostat,,, could that cause that???
You can check to see if the T-stat is working by letting the car warm up and check to see if both hoses are hot. This would mean the t-stat is opening. They are not that expensive. I would just replace anyways.
it was head gasket. i just re did it.... good too go.. now my car still surges for an idles too.. any ideas why??? my car came with a aftermarket 68mm throtle body.. maybe i should have tps adjusted differently from stock or what???
what rpm does it idle at?
slickrickauto
09-06-2007 03:41 PM
omgwtfhaxnub
03-20-2005 03:29 PM
