EF/ED rear brake swap INFO
4G HATCHES NEED:
90-91 CRX REAR TRAILING ARMS, 90-91 CRX rear brake lines, 90-93 TEG 2dr Ebrake cables
OR
90-93 TEG REAR TRAILING ARMS, 90-93 TEG rear brake lines, 90-93 TEG 2dr Ebrake cables
OR any combo of the 2
2G CRX NEED
90-91 CRX REAR TRAILING ARMS, 90-91 CRX rear brake lines, 90-91 CRX Ebrake cables
OR
90-93 TEG REAR TRAILING ARMS, 90-93 TEG rear break lines, 90-91 CRX Ebrake cables
4DR ED's need:
OR
90-93 TEG REAR TRAILING ARMS, 90-93 TEG rear break lines, 90-93 TEG 2dr Ebrake cables
MASTER CYLINDER INFO
DX: 13/16
HF: 13/16
SI: 7/8
EX: 15/16
use booster that comes w MC
IF U WANT TO USE TEG 15/16
you also need the booster
THE PROP VALVE:
you can use it it helps alittle NOT NECESSAARY
USE CRX 90-91 SI
OR 90-93 TEG NON ABS
MY REAR
MY FRONT
i personally have teg 15/16 and booster w SS lines
FRONT: ITR calipers in front w 11.1 prelude rotors on EX knuckles
REAR: STOCK REAR ARMS w/ 1 90-93 teg rear disk hub spindle caliper and rotor
and 1 91 SIR CRX rear disk hub spindle caliper and rotor
[Modified by Usdm ED9, 5:50 PM 7/20/2002]
[Modified by Usdm ED9, 5:55 PM 7/20/2002]
[Modified by Usdm ED9, 1:07 AM 7/21/2002]
OR
2G CRX NEED
OR
4DR ED's need:
OR
DX: 13/16
HF: 13/16
SI: 7/8
EX: 15/16
THE PROP VALVE:
USE CRX 90-91 SI
MY REAR
MY FRONT
Re: EF/ED rear brake swap INFO (Usdm ED9)
what did you need to do to put on those front brakes????? my friend put on a master cylinder from a 87 accord hatch thing, you know the info on that one???
Re: EF/ED rear brake swap INFO (ED9Hybrid)
88-89 and 90-91 have different bolt patterns for the master cylinder to booster.
[Modified by EF'n Fast, 1:03 AM 7/21/2002]
