ebay Stainless steel brake lines
Old 11-13-2008, 04:00 PM
turboef90's Avatar
Default ebay Stainless steel brake lines
has anyone bought them???they fit good etc.??? i gotta buy new lines from the calpers to the chassi. i called the local auto parts store they wants 30 bucks for ones side so i figure id just buy the ebay deal. just wanting feed back before i do buy them thanx
Old 11-13-2008, 04:05 PM
kay@neighborhoodtrends's Avatar
Default Re: ebay Stainless steel brake lines (turboef90)
i used them about a year ago they were crap
just my 2 cents
Old 11-13-2008, 04:09 PM
Rainman
SIred91's Avatar
Default Re: ebay Stainless steel brake lines (kay@neighborhoodtrends)
Honestly, stock is the best unless you just want the bling. And I track my car a lot too. I have had ZERO problems w new stock lines...braided stainless, no matter the brand, in my opinion is just not as good as OEM honda.
Old 11-13-2008, 04:16 PM
dacrxguy's Avatar
Default Re: ebay Stainless steel brake lines (SIred91)
this is your cars health and yours were talking about and u want to trust egay
Old 11-13-2008, 04:22 PM
dr_latino999's Avatar
Default Re: ebay Stainless steel brake lines (dacrxguy)
Beat me to it, DOT approved or go home. This is something that just shouldn't be skimped on.
Old 11-13-2008, 04:33 PM
CRX Toad's Avatar
<FONT SIZE="5"><FONT COLOR="red">AMEN</FONT></FONT>
I have run stock OEM lines for 5 years with no issues!
It amazes me the placebo effect SS lines have on people "dude I notice my brakes were firmer"
Old 11-13-2008, 04:39 PM
acmoc's Avatar
kingmotorsports sells some that are good, I'm using them rite now. but like Toad said, I can't tell a difference, but this like anything associated with your safety; you should not skimp on it.
Modified by acmoc at 6:09 PM 11/13/2008
Old 11-13-2008, 05:42 PM
civic4gscott's Avatar
i have ebay stainless steels they work perfect they have been on my car for around a year now
Old 11-13-2008, 06:02 PM
blaak-crx's Avatar
Default Re: (civic4gscott)
Remember, OEM brakes line will tend to swell up/expend when the brake fluid gets "hot" on the race track. So good quality SS braided lines will prevent all of that and keep the brake pedal OEM firm (not firmer). For street use, totally useless.
Also depending on what track you drive, braking zones may be less demanding. So, OEM brakes lines may just be fine.
Old 11-13-2008, 06:51 PM
Crx Jimmy's Avatar
Default Re: (blaak-crx)
if the eBay lines in question are the ones with the blue ends and are from a Canadian seller they are ok. I have been running them for 6 years. They are made in canada they aren't Chinese . No problems here
Old 11-14-2008, 02:31 AM
turboef90's Avatar
ya im not doing any track racing or anything just thought why not spend the money on braided lines. they cost the same thanx for the feed back guys
Old 11-14-2008, 03:00 AM
bprsk8r4272's Avatar
Default Re: (Crx Jimmy)
i have those ones wit the blue ends haven't installed them yet though
Old 11-14-2008, 03:07 AM
CRX Toad's Avatar
If you get your fluid that hot you are not managing the systems of your car well. There is no point to get the fluid that hot.
Especially in an EF.
Old 11-14-2008, 07:42 AM
89s1's Avatar
Default Re: (CRX Toad)
the reason everyone is so sure stainless lines do wonders is because they were on an un-bled system filled with OLD fluid before.
Now they have these magic lines and a fresh bleed with new fluid.
take it from me. the bleed and new fluid is what they are feeling.
Old 11-14-2008, 07:56 AM
Default Re: (89s1)
You also have to factor in that brake lines will deteriorate over time, and most of our OEM equipment has been around exposed to the elements since the Soviet Union. The simple act of replacing the lines for a set either OEM / quality aftermarket would allow for less expansion and a slight piece of mind upgrade.
Old 11-14-2008, 11:33 AM
turboef90's Avatar
when you say blue ends you mean these???
http://cgi.ebay.com/ebaymotors...ories
Old 11-14-2008, 01:00 PM
Pirate General...YARRRR
Ass$nyper's Avatar
Default Re: (turboef90)
Toad, my good doc, 89s1 and the rest of you.
Thank you, I have faith HT still has a member base who have held a 10mm wrench.
Old 11-14-2008, 02:33 PM
those are the exact ones i have which i believe crx jimmy was talking about
Old 11-14-2008, 02:59 PM
Rainman
SIred91's Avatar
Facepalmslap.
Old 11-14-2008, 04:39 PM
89s1's Avatar
Default Re: (***$nyper)
flane nut, ratcheting, or box end?
TwoKSiR
12-01-2007 07:45 PM
james_c._78
13
10-18-2007 11:17 AM
HybridKOOP
Welding / Fabrication
24
09-20-2007 07:03 AM
jolt-tsp
08-29-2006 02:55 PM
idriveadelsol7
05-18-2005 06:02 PM
Quick Reply: ebay Stainless steel brake lines
