drive axle seals part number?
Old 05-21-2012, 09:52 AM
Crxmick's Avatar
Default drive axle seals part number?
i have a question about OEM drive axle seals on my 1987 honda civic crx HF manual transmission. I am not sure what the part numbers for drivers and passenger side I am suppose to order on the website: www.hondaautomotiveparts.com (majestic) I think these are the numbers, but why would they be 2 different seals? they both look the same size on the transmission when I look at it. Part number 91205-PL3-A01 010 001 OIL SEAL (35X56X8) (ARAI) and 91216-PA0-003 013 001 OIL SEAL (22X35X7) (ARAI). Maybe I am ordering the wrong seals? Anyone know the Honda OEM seal part number if I am wrong? thank you for your help.
Old 05-21-2012, 11:23 AM
usdmed9's Avatar
Default Re: drive axle seals part number?
You should probably try to ask this in the classic Honda section as this is 88-91 section, but most axle seals I have seen are different between the driver and passenger side.
Old 05-21-2012, 03:19 PM
Spug's Avatar
Driver side is 91206-PE6-003 OIL SEAL (35X56X8) hondaautomotiveparts.com
Passenger side is not listed on that site.
Hondapartsdeal.com lists the passenger side as 91205-PE6-004 OIL SEAL (35X68X9) (NOK)
Passenger side seal isn't on the same part of the tranny housing as the drivers side, so it's not listed with the same diagram.
Hondapartsdeals.com lists both parts.
raidacaipo
23
03-22-2021 08:06 PM
james d
Transmission & Drivetrain
05-01-2013 07:21 PM
Omega Blaze
10-29-2011 12:16 PM
EFresh
07-31-2006 01:44 PM
Quick Reply: drive axle seals part number?
