dpfi to mpfi. resistor box need with obd1 injectors.
Old 06-19-2007, 09:18 AM
dem0nk1d's Avatar
Default dpfi to mpfi. resistor box need with obd1 injectors.
i need to get started on the dpfi to mpfi injector conversion. i was wonder since i have a wrecked eg. i could use th injector clips and plugs from the old obd1 harness, to do the dpfi 2 mpfi conversion. I shouldn't need to wire in the resistor box, because of the injectors being peak hold. Or is it saturated injectors...
Old 06-19-2007, 10:14 AM
wickedEFguy's Avatar
Default Re: dpfi to mpfi. resistor box need with obd1 injectors. (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">i need to get started on the dpfi to mpfi injector conversion. i was wonder since i have a wrecked eg. i could use th injector clips and plugs from the old obd1 harness, to do the dpfi 2 mpfi conversion. I shouldn't need to wire in the resistor box, because of the injectors being peak hold. Or is it saturated injectors...</TD></TR></TABLE>
Those injectors you have from the EG are saturdated so you won't need a resistor box.
Old 06-19-2007, 08:51 PM
slow_rex_will's Avatar
OBD0=Resistor Box Neede
OBD1=No Resistor Box Needed
Modified by slow_rex_will at 5:43 PM 6/20/2007
Old 06-19-2007, 09:23 PM
cr-x-91's Avatar
u got it backwards bud
0bd0=resistor box
0bd1=no resistor box
Old 06-19-2007, 11:11 PM
Bob_760's Avatar
Default Re: (cr-x-91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 &raquo;</TD></TR><TR><TD CLASS="quote">u got it backwards bud
0bd0=resistor box
0bd1=no resistor box</TD></TR></TABLE>
QFT
If you run OBD-1 or OBD-2 injectors all the resistor box wires all need to be wired together in some fashon. You can repin them into the OBD-1 resistor box cap to keep it clean.
Old 06-20-2007, 04:44 PM
0bd0=resistor box
My Fault, Fixed it.
Blame it on the kush!
makoto
04-11-2007 10:38 AM
RudeLude
04-22-2006 07:36 AM
HiProfile
06-20-2005 02:34 PM
7rrivera7
01-17-2005 02:07 PM
my crx is rhd
12-29-2004 09:13 AM
Quick Reply: dpfi to mpfi. resistor box need with obd1 injectors.
