Do I need a flex pipe for exhaust?
Old 08-03-2002, 04:04 PM
1990hondaHF's Avatar
Default Do I need a flex pipe for exhaust?
My HF didn't have one. Does my ZC need one?
Old 08-03-2002, 09:00 PM
Default Re: Do I need a flex pipe for exhaust? (1990hondaHF)
Bump
Old 08-03-2002, 09:15 PM
Mugen Dom's Avatar
wut do u mean??? are u using a header r wut??? there is no fles pipe on the si or zc from honda
Old 08-03-2002, 09:22 PM
Default Re: Do I need a flex pipe for exhaust? (jdmb18hatch)
A flex pipe...that is part of the exhaust that is "flexible". Normally, it has some sort of criss-cross meshing around it. Most cars have this just after the header(s). As I've never seen an SI model, I wouldn't know if it had one or didn't. I bought an HF which didn't have one....not like massive torque is an issue(which is the main reason cars have them.) I thought that the ZC might need one considering the power it has. I was just wondering if anyone has used one or has even needed one?
Old 08-03-2002, 09:26 PM
ijjz's Avatar
I know what you mean man, looks like an over sized stainless steel braided line. Do you need one? That I'm not sure of.
Old 08-03-2002, 09:29 PM
Mugen Dom's Avatar
i dont remember seeing any honda with a flex pipe thats wut i thought u meant but people add names to things and sometimes things get confused
Old 08-03-2002, 09:57 PM
crx(gator)'s Avatar
i know what your talking about, its this piece that is between the exhaust manifold and the cat. converter, that is made up of springs that way if there is too much torque the exhaust manifold wont crack since it can move a bit at the bottom, im pretty sure its a good idea to have that way like i said it wont crack or break the e.manifold...
Old 08-04-2002, 09:12 AM
BigMig's Avatar
if your not using the bolts with the springs that connects the header and cat then you should be using a flex pipe cuz the header needs some play when the engine moves
jbrokos307
10
10-16-2009 08:39 AM
crex23
07-16-2009 04:49 PM
kojack_0
10-06-2008 08:59 AM
janz3n
07-14-2008 02:35 PM
the niz jiz
12-20-2004 05:16 PM
Quick Reply: Do I need a flex pipe for exhaust?
