diy dpfi-mpfi swap made easy!!!
Made this to show people how simple and non confusing this can be if done with a good right right up.. I know there are a few out there that are really good but hear is another one hope this helps some people out!!!! Enjoy
Note: you must use your stock dpfi engine harness!!
Re: diy dpfi-mpfi swap made easy!!!
EDIT: I forgot to add this to the diagram I drew when you connect the positive wires for the injectors to a15 you do not cut it you splice in to it by stripping back some insolation on the wire.. and also when doing the mpfi swap you must move the 2 outer wires on the throttle position sensor plug!!
Very helpful i like this post a lot. Prob going to do this soon so i can eliminate one of my O2 sensors. i have 4-1 headers that only have one bung. I also want to get a chipped ecu for tuning. Thanks a lot for the info.
Yes that's one of the reasons I made this I know I'm new to this site but it gets old seeing a new post like every other day saying need help with my mpfi swap. and seeing the mess people make of there wiring and hack jobs. its really simple to do if you have a decent right up that explanes it and shows it how it is. I mean some one who never did mpfi swap can understand this right up its mad that simple. so enjoy people hope this helps some people out in the future!!!! Maybe it could be a sticky if the mods like it enough and think it will benefit a lot of people on hear? But I won't get my hopes up lol
Thanks. and yes I agree most people do make it out harder then it really is that's why I made this so all the info is in one place and is correct. And I made it as easy as I could so people can understand it
wow this is amazing wish when i did my mpfi swap i had this diagram makes me feel like mpfi swap for dummys lol sweet post bro. curious anyone know why my car bogs down 90 crx mpfi swap d15B7 engine when i turn sharp or stop hard it dies or bogs down an if im gunning it sometimes it bogs down such a pain if any ideas please reply thanks
This needs to be on the front page and highlighted. Wish I saw this weeks ago before i sent my harness out but O well. Maybe I can play around now and make one thanks to you!
For those not fortunate enough to find the Round SI Dizzy plug, you can also use the stock DPFI dizzy plug and use the green 2 plug from a 88-89 integra. That way you can run the C1/C2 wires separately from the square plug. Ill have to snap a pic of my Set up to clarify.
ok i gotta few questions, if i do this method of dpfi to mpfi conversion i can still use my stock (d15b2) harness which is what is in the car right now with the d15b8 with the dpfi off my b2. runs like **** so i want to put the b8 stock intake manifold back on the motor and convert it to mpfi
Nice.
I was reading about this for a while and didn't quite understand it.
Remember, you can re-use the injector wires from the dpfi harness... that way you don't have to run so many wires...
Deffinately gonna be using this in next couple of weeks!! If there a mobile friendly version somewhere of the distributo wiring part?? Its so fuzzy I can't read it! Thanks for the write up!
awesome write up, only thing I think you should change is the injector numbers to match the normal cylinder numbers, so #1 would be closest to the timing belt and #4 would be closest to the dizzy. it would just save some confusion.
