Did search, but not enough info. How do you program chip for ecu?
Old 09-18-2004, 04:36 PM
hughesl's Avatar
Default Did search, but not enough info. How do you program chip for ecu?
I read through any searches I could find. I am planning to change up a number of things on my car. I am looking at getting a wide band O2 and I would like to modify my ECU program. I am currently running a PR3 OBD0 ECU.
-Where do you buy the prom burner? I have seen some for sale on here. If you wanted to pic up a new one where do you get it?
-Do you have to break the solder on the ECU and remove the old chip?
-Can you flash a chip more than once or do you have to do a new one each time?
-What software do you use?
-If you have a set of mods, can you get a program online from someone else with similar mods to start the tuning from?
I know this is a lot of questions, I appriciate any help on this subject.
Old 09-18-2004, 05:12 PM
Mr_CRX's Avatar
Default Re: Did search, but not enough info. How do you program chip for ecu? (hughesl)
Theres a ton of info on pgmfi.org about honda ECU chipping.
I'll see what I can answer for you here.
-You remove the old chip, and solder in a socket. This way you can pop new chips in and out all day and not have to do any more soldering.
-Some chips are only flash-able once, but there are re-writeable (re-flashable?) ones too that you can erase and burn a new set of maps on as well.
-Theres a few programs for obd0, turboedit is one of them, and i believe Crome does obd0 as well as obd1.
Hopefully that input helps a bit. I'm still new to it myself, but I'm learning from a friend of mine who is pretty involved in the chip burning/ecu hacking. Good luck!
Old 09-19-2004, 04:29 AM
hughesl's Avatar
Default Re: Did search, but not enough info. How do you program chip for ecu? (Mr_CRX)
Thanks, I am just starting to touch the tip of the iceburg on this.
I currently do not know anyone that is doing this type of tuning.
I do have a friend that has the programmable AEM ecu, but I dont have a couple grand laying around to get that type of system.
Old 09-19-2004, 05:10 AM
Sikocivic's Avatar
You should be able to find everthing you need here.
http://www.homemadeturbo.com/forum/index.php
WeB
Engine Management and Tuning
01-19-2010 11:17 AM
en00be
02-09-2009 10:43 AM
nudeinthelude
04-21-2008 09:04 PM
tdog
02-03-2003 10:14 PM
Quick Reply: Did search, but not enough info. How do you program chip for ecu?
