dashboard lights, clock, radio not working! help - Honda-Tech
Old 06-06-2009, 08:17 PM   #1
Default dashboard lights, clock, radio not working! help
So my Dashboard Lights, clock, and radio are not running right now.
I realize it could be a fuse or a ****ed up wire, but is there anything special i should look at? i find it really odd that all three are out at once, i checked all the fuses and they all came up how they were supposed to.
im stumped:-/
(89 CRX SI 1.6L SOHC ZC)
also if anyone has any websites that show how the fuses go in exactly that would help
hellraiser7492 is offline   Reply With Quote
Old 06-06-2009, 08:40 PM   #2
Default Re: dashboard lights, clock, radio not working! help
im stumped:-/
i just went and checked and according to the diagram under the fuse box, some of the amps were in the wrong place, i fixed them(like some had where 7 and 9 were supposed to be empty and 7 had a 30 amp in it..
hmm wtf?)
Old 06-07-2009, 07:28 AM   #3
EFB055
~sp33~'s Avatar
Often the accessories will share a fuse, so if one goes, they all go.
It could have been a short somewhere, so if you replace it, and it blows again, start looking for exposed wires.
~sp33~ is offline   Reply With Quote
Old 06-08-2009, 02:30 AM   #4
sorry i took so long to reply
the weird thing is,
all the fuses are correct and working, and i dont wanna like take it apart and whatnot without looking for more things rather then just taking off the dash
Old 06-08-2009, 07:40 AM   #5
88whitehatchidaho's Avatar
does it have an aftermarket cd player? almost every time i see problems like this it is usually in the wiring for the cd player i could be wrong but its some where to start i have fix about four or five that were like that(tape comming off connections and shorting out each other, because it seems like around here nobody has ever heard of butt connectors lol)
88whitehatchidaho is offline   Reply With Quote
Old 06-08-2009, 08:12 AM   #6
dr_latino999's Avatar
How are your turn signals? I have a weird feeling this could be an ICU related issue.
dr_latino999 is offline   Reply With Quote
Old 06-09-2009, 09:10 AM   #7
Quote:
its sort of aftermarket but not like a new *** one it's fairly old. and the cd player before it actually shorted wires but we cut them and rewired them.
Quote:
my turn signals are fine, the only thing that is odd with the signals is when i press my hazard lights they click and take a sec or two to start and make a buzzing sound like crazy before they start.
any ideas?]=
Old 06-09-2009, 09:35 AM   #8
Cnile1's Avatar
Seems like you have a short somewhere...
The best thing to do is run through the wires.
You should find the answer if you do that.
Your dash doesn't have the fuse diagram on it?
Cnile1 is offline   Reply With Quote
Old 06-09-2009, 09:37 AM   #9
its hard to run thru dash wires tho]=
but yeah it does have a fuse diagram but the fuses aren't shorted
Old 06-09-2009, 07:59 PM   #10
it will only take a few hours to pull your dash out and look at the wires...my dash harness caught fire. So i have the whole thing ripped out right now.
sepheroth is offline   Reply With Quote
Old 06-09-2009, 08:01 PM   #11
pull the glove box, center console, steering wheel, turnsingnal/wiper, gauge cluster, and there is around 5 main bolts and the whole dash comes out
Old 06-09-2009, 10:55 PM   #12
Cnile1's Avatar
You don't even need to take out your whole dash.
Try putting on all the switches to your lights that are out and stick a circuit tester through every wire. The wires that are short won't light up the circuit tester. You'll have to replace the section of the wire that is short. Then it should work. You gotta troubleshoot the problem bro. I think all the wires run through the fuse box. You can reach them all right there by the fuse box.
Clock Backlight not working. Canucksfan101 Honda Accord (1990 - 2002) 4 12-31-2014 04:02 PM
4th Gen - Clock and Radio stopped working Mike95lude Honda Prelude 1 10-14-2011 03:00 AM
dashboard does not light up. help!! kenny707 Honda Civic / Del Sol (1992 - 2000) 4 01-28-2009 06:41 AM
Dashboard lights don't work on my 89 Civic... E Swift Honda CRX / EF Civic (1988 - 1991) 8 12-17-2002 04:51 AM
Clock and Radio not working after ECU reset... digitalspice Acura Integra 3 02-16-2002 06:34 PM
Tags
2001, accord, cd, clock, crv, dashboard, diagram, fuse, good, honda, integra, lights, player, radio, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
