Sohc Zc question
Old 06-08-2009, 01:48 PM
JdmCrxKid's Avatar
Default Sohc Zc question
i am changing my throttle body gasket and i do not know what gasket to buy...i tried a crx 1.6 that didnt work out.....
should i try to buy a 89 integra gasket
the motor came off of a integra in japan..
Old 06-08-2009, 11:46 PM
Tyson's Avatar
Default Re: Sohc Zc question
huh. its different?
can you take a pic of the two?
Old 06-09-2009, 09:15 PM
stevescivic's Avatar
it should be the same gasket as I am certain that the sohc zc engine was the D16A6 engine but with a more aggressive camshaft no?
Old 06-09-2009, 09:19 PM
JdmCrxKid's Avatar
ya their camshaft is more aggressive..but i found my gasket
now im having issues with it bogging.....
i changed the tps sensor and its running check engine code 5 & 7...
dont know wats wrong with it after i check the wires and vacuum lines a few times
Old 06-09-2009, 10:07 PM
EFB055
~sp33~'s Avatar
Was the engine from an 89 Integra? If it was an obd1-2 model then there would be a difference.
Old 06-09-2009, 10:34 PM
CRX=MC2's Avatar
does the motor have a strange block off plate on the back side of the head? It would be passenger side, firewall side, up near the valve cover....If if does, the motor came from the jdm carburetor type zc's. That would mean its has been swapped to mpfi. I would say someone used usdm sohc 1.6 intake ie stock si stuff likely, stock TB ect.
I hope this helps, to be of anymore help we would need pictures... or the intake three digit code, good luck.
jdmcrx1819
02-17-2014 10:43 PM
crxsirg
06-15-2011 03:42 PM
Wheelman-CZ
11-15-2006 04:41 AM
civicflow
10-01-2004 04:37 PM
crxhybrid85
08-08-2004 10:21 AM
Quick Reply: Sohc Zc question
