D16z6 swap...tranny question
Old 12-07-2006, 11:10 PM
supracrx's Avatar
Default D16z6 swap...tranny question
looking at a full swap that a friend has...d16z6 swap into 88 CRX SI with d16a6
i need conversion harness, ECU either a p28 or pr3? correct me if i'm wrong. then i can use SI harness from my car...will injectors work? use the z6 or a6 injectors? are they different impedance or anything? and harness will work with the z6 ones if i use those? and then the mount i will need to take off the a6 engine block and put it on the z6 right? and i might need to grind it off a little?
as for now the tranny....i have a 88 SI tranny...that i'm going to use....i know the different spline counts and all that stuff. if i use the 88 tranny i will need the 88 clutch disc, pressure plate, throwout bearing? and i use the z6 flywheel that its coming with? correct me if i'm incorrect.,,,,
i need to make sure the car is up and running in a day because i can't keep the car at a friends house for more then a weekend...thanks
Old 12-07-2006, 11:37 PM
njn63's Avatar
Default Re: D16z6 swap...tranny question (supracrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supracrx &raquo;</TD></TR><TR><TD CLASS="quote">looking at a full swap that a friend has...d16z6 swap into 88 CRX SI with d16a6
i need conversion harness, ECU either a p28 or pr3? correct me if i'm wrong.</TD></TR></TABLE>
I know the p28 is the right one. Don't know what the pr3 is offhand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">then i can use SI harness from my car...will injectors work? use the z6 or a6 injectors? are they different impedance or anything?</TD></TR></TABLE>
Either will work. If you use the z6 ones though you need to remove the resistor pack and connect all the wires in it so it just goes straight through. If you search (probably under obd1 conversion) there should be info on that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and harness will work with the z6 ones if i use those?</TD></TR></TABLE>
Different plugs if i remember right.
I don't know 100% about the rest of it so i'm not going to answer.
Old 12-08-2006, 03:29 AM
killa rex's Avatar
p28 ecu..92-95 civic ex/si
L mount on timing side from A6.
Enlarge the hole for the mount on the timing cover.
If u gonna convert to obd1..use the z6 injectors & dizzy.
Get the clutch kit for your tranny. Use the z6 flywheel. Might as well replace the pilot bearing.
Old 12-08-2006, 04:20 AM
mondo375's Avatar
Unless you wire it yourself you will need the jumper harness for the ECU and P28 is the correct one.
I got my ECU, Vtec subharness, and Dizzy harness/jumpers from Rywire.com. It was plug and play and works great. I highly recommend it if your not doing it yourself.
Either or...i just used my a6 injectors and it works great. I dont recall the name of the sensor on the back of the block on the a6(maybe Temp sending?) but on the z6 its under the dizzy. The plugs are different on the two so i had to use the plug from the z6 harness to relocate it.
You will need the Driver side mount off the a6 and use it on the z6. I think its the upper timing belt cover that causes the problem so choices were grind a bit of the cover or mount...i chose cover since its plastic and doesnt hold my motor in place.
The dont think a regular 88 clutch kit wont fit on the z6 flywheel. If im not mistaken the surface area on teh z6 is bigger so the clutch kit wont line up to the mounting points. I purchased a fidanza lightened flywheel for my swap and when i tried to use a stock clucth it didtn line up. I had to purchase the upgraded version of the 88 clutch that has the increased surface area for 92+ flywheels.
GL and pm me if ya need more info.
Old 12-08-2006, 09:08 AM
supracrx's Avatar
^^ can anyone confirm that the 88 clutch doesn't work....iu need to know so i know what i'm dealing with....
also i do planning on getting the rywire complete conversion kit thing....as for the injectors..will the stock SI harness injector plugs go right up to the z6 injectors? or do i have to use z6 harness plugs to the harnesS?
Old 12-08-2006, 10:15 AM
mondo375's Avatar
Default Re: (supracrx)
yea plugs are the same.
*edit* found this https://honda-tech.com/zerothread?id=1807779
read 2nd post. So if your using the z6 flywheel u will need the upgraded version of an 88 clutch or 90-91 tranny. Probably cheaper to just get the clutch rather then new tranny and clutch
Heres where i got my clutch and u can see where they offer regular and bigger clutch for 88's http://www.clutchcityonline.com/honda_crx.htm
Modified by mondo375 at 11:35 AM 12/8/2006
Old 12-08-2006, 12:21 PM
supracrx's Avatar
damn i was hoping to save some money...but i guess i'll have to buy an upgraded clutch...
Old 12-08-2006, 10:43 PM
supracrx's Avatar
so no matter what...i'm gonna have to use the z6 flywheek, my 88 SI tranny with a 88 clutch kit with upgraded surface area right? if i use the regular 88 clutch kit...it won't be right for the z6?
Old 12-08-2006, 10:44 PM
supracrx's Avatar
would i be able to just use the a6 flywheel and bolt it on to the z6 motor?
Old 12-09-2006, 04:54 AM
jackinthetrunk's Avatar
im in the works on dropping a d16z6 too. Cant wait until I have enough money to start buying the parts. BUMP for some info.
Old 12-09-2006, 04:54 PM
supracrx's Avatar
yea wondering about the a6 flywheel on the z6.
if not i might have a 91 SI tranny that i can use
Old 12-22-2006, 07:49 PM
supracrx's Avatar
does anyone know if the a6 flywheel will work on the z6 or the d15b?
Old 12-22-2006, 11:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supracrx &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if the a6 flywheel will work on the z6 or the d15b?</TD></TR></TABLE>
dood, just read up the page, it explains everything. The flywheel doesnt matter on the motor, the year of tranny is what matters.
Old 12-23-2006, 04:34 PM
supracrx's Avatar
dude i know what is said above ^^^
but what i'm asking is i know the 88 will not work on z6 flywheel because of the surface area being greater on the z6....but what im asking is if i use the A6 flywheel from my car and slap it onto the z6 motor can i use my clutch...i just replaced my clutch about 10000 miles ago and don't wanna change it out again as of now...THANKS FOR THE HELP
streetsold6teeny8
02-11-2009 03:31 PM
Citystars
43
11-24-2007 04:02 PM
jadugartir
17
02-25-2005 02:50 PM
Jeff_G
09-08-2002 04:48 AM
Quick Reply: D16z6 swap...tranny question
