D16A8 made 102HP@WHEELS
#77
Re: D16A8 made 102HP@WHEELS (kantfadedisazn)
its a DOHC... not a SOHC.
Im looking to get some cams as well - i just need to get the best profile without changing ECU for starters - maybe down the track... and might get a worked Throttlebody just to let it breathe better. It looks like its running pretty rich at the higher RPM so with a bit of mods I can try get it to even out..
#81
Re: (vteckillenzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc »</TD></TR><TR><TD CLASS="quote">ok then why do on some sites i seen they are quoting 2 diff c/r for the zc and the one with no cat has low c/r
9:3.1<<witout cat
9:5.1<<with cat
are they just blowing **** out there *** or what</TD></TR></TABLE>
Rover increased the compression ratios on the cat equipped cars to make up for the power that was lost by using the cat - this happened at the same time that the UK law changed, and cats were made compulsory.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">on UK crx, they offered SOHC and DOHC engines</TD></TR></TABLE>
Wrong.
We got the D16A9, and the B16A1 - Thats it.
There is an awful lot of incorrect information in this thread.
9:3.1<<witout cat
9:5.1<<with cat
Wrong.
#83
Re: D16A8 made 102HP@WHEELS (SINISTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINISTR »</TD></TR><TR><TD CLASS="quote">its a DOHC... not a SOHC.
Im looking to get some cams as well</TD></TR></TABLE>
your single over head CAM needs CAMS? wow, i want one of those motors
#84
Re: D16A8 made 102HP@WHEELS (gold EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold EF »</TD></TR><TR><TD CLASS="quote">your single over head CAM needs CAMS? wow, i want one of those motors</TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINISTR »</TD></TR><TR><TD CLASS="quote">its a DOHC... not a SOHC</TD></TR></TABLE> Is there something here I am not understanding?
#86
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINISTR »</TD></TR><TR><TD CLASS="quote">hey Guys,
I just had my CRX Dynod on the weekend.
Its running a D16A8 Auspec motor, with Intake, RSR headers and Exhaust - and made 102HP@wheels (76kw)
There are plans for some Cams as well - but unsure on a profile yet, as I want to use the stock ECU and valvesprings - nothing too 'hardcore'.. I'll potentially be happy with about 115-120@wheels.
I can say that the RSRs made a bit of a diff as other JDM ZCs there made between 90-100HP with similar mods
What can you guys recommend for other not so expensive mods but fairly 'good' gains?
cheers
Mike </TD></TR></TABLE>
LOL!! If you say so
cheers
LOL!! If you say so
#87
Re: (PaImportTuner)
yeah - as i said this is one of the dynos here, there is another one here and a comparison my friends RX7 Twin Turbo made 237 on the dyno I did, and then he went on the other one and only made 207 - so thats a further loss...
anyway - its only a tuning device isn't it? there is no way of getting the 'true' figure anyway you try.
#88
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold EF »</TD></TR><TR><TD CLASS="quote">ive seen a guy at our old napa machine shop (where i used to work) with a single cam si milled the head 0.140 (one hundred and fourty thousandths). he had to remove the valves because he cut soo much off the head that it would have shaved the valves. this is all he did. he made 130 whp with intake headder exhaust. car ran 14.2. most amazing thing ive ever seen. only lasted 2 months... </TD></TR></TABLE>
daum thats kinda living on the edge im suprised there was no clearance problems... did you guys run a compression test i wanna know what #'s you got?... you guys use a oem head gasket with that or a 2 ply?
#89
Re: (SINISTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINISTR »</TD></TR><TR><TD CLASS="quote">I can't unfortunatelly go out and spend $1000 or $2000 on a set of CAMS</TD></TR></TABLE>
Cams don't cost $1000-$2000 for a set. Even if we are talking about DOHC VTEC cams (B-series, at least), the cost of a good set is well under $1000. The only problem you are likely to encounter with ZC cams is lack of availability. But provided you can find them, there is no reason why they should cost more than a set of LS/B20 cams - about $400 or so. And that's for new cams, not regrinds. The only thing to keep in mind is that you generally need a spring/retainer set. And this typically sets you back another $200-$300 (or so). But even then, the total cost is below $1000.
#90
Re: (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">Cams don't cost $1000-$2000 for a set. Even if we are talking about DOHC VTEC cams (B-series, at least), the cost of a good set is well under $1000. The only problem you are likely to encounter with ZC cams is lack of availability. But provided you can find them, there is no reason why they should cost more than a set of LS/B20 cams - about $400 or so. And that's for new cams, not regrinds. The only thing to keep in mind is that you generally need a spring/retainer set. And this typically sets you back another $200-$300 (or so). But even then, the total cost is below $1000.</TD></TR></TABLE>
this is true
look up Crespo cams for the ZC. real good and affordable.
also i would never tell anyone to buy piece of **** stuff. but their zc cams are great and work for a lot of people in the tristate area. i'll post alittle info here some people cant understand what they read so i'll explain whats for what application. the powerbands and specs are on their site.
<u>$365/pair</u>
stage 2 for they are like the type-r cams for the zc. good with FI and Allmotor.
stage 3 for high psi turbo applications..
stage 4 for roadracing.
<u>$405/pair with high lift valvesprings $485</u>
stage 5 for High compression ALL motor.
no where near $1000 and you get valvesprings for $80 more in the stg5kit. you dont need the springs supposebly if you get anything under stage 5. but i would get them anyways and ask if they could add them in on the other kit if its only $80.
http://www.crespocams.com/serv...+Cams
i also know WEB CAMS made some nice regrinds for the ZC. and are cheap too.
this is true
<u>$365/pair</u>
#91
Re: D16A8 made 102HP@WHEELS (jaydeum4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeum4lyfe »</TD></TR><TR><TD CLASS="quote">daum thats kinda living on the edge im suprised there was no clearance problems... did you guys run a compression test i wanna know what #'s you got?... you guys use a oem head gasket with that or a 2 ply?</TD></TR></TABLE>
we used a metal head gasket and took the center out, so it was even thinner. the compression was off the 300psi guage. we estimated it to be somewhere around 14.0-1
#92
I agree - $2000 is probably an overkill but pls remember that Im in OZ, anything from the US is about double just in price + shipping - so a set of $400 CAMS i'll be looking at about AU$1000 by the time I get them.
Im not going to rule out I won't go for something better than a set of regrinds but thats in the future. A set of Biller Cams here costs over AU$800 up to $1200 - thats where my 1-2K came in. I can get regrinds here for AU$350 - just a mild grind whihc should give me B16A hp increase without swapping springs and retainers.
Ive been asking around what is the best profile to fit to a ZC, without swapping valve springs and retainers, with running a stock ECU - but I havent had any positive answers. Cams are usually premade and people can't give me an idea on profiles.
Thanks for the comments guys - hope you can take into consideration the $ conversion and $1000 in australia is about $750 in the US.
#93
Re: (SINISTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINISTR »</TD></TR><TR><TD CLASS="quote">I agree - $2000 is probably an overkill but pls remember that Im in OZ, anything from the US is about double just in price + shipping - so a set of $400 CAMS i'll be looking at about AU$1000 by the time I get them.
Thanks for the comments guys - hope you can take into consideration the $ conversion and $1000 in australia is about $750 in the US.</TD></TR></TABLE>
they are new cores not regrinds.
i just converted it.
stage2-4 is $497AU
stage5 is $552AU with valvesprings $661AU
shipping is like $274AU to Perth (WA) 6153 from where i live on the east coast, i dunno how much from the company.
just for future renference.
stage2-4 is $497AU
