D16A6 (Si) head gasket job - Honda-Tech
Old 05-31-2010, 08:10 PM   #1
Crazy Honda Guy
Deetz's Avatar
Default D16A6 (Si) head gasket job
Well, i picked up a cheap 5 speed 1990 Civic Si a couple days ago for $500. Car is in ok condition and can use a little TLC. On the way home i noticed how much white smoke was burning......head gasket
I got a new full oem gasket kit, went out to the garage and started ripping the engine apart. Turns out the engine still have the original fiber/paper type material head gasket still the, it sure was leaking, lol
Just looking for any input on the best way to clean off the old crap....what is the best way?
Here's a couple pics of the car and where i'm at.........
couple cell phone pics
Engine ripped apart
decided to wrinkle coat the valve cover while i was at it
Deetz is offline   Reply With Quote
Old 05-31-2010, 08:28 PM   #2
BrayzieEF9's Avatar
Default Re: D16A6 (Si) head gasket job
nice find clean even though paints faded
BrayzieEF9 is offline   Reply With Quote
Old 05-31-2010, 08:31 PM   #3
BrayzieEF9's Avatar
have u tried a razor?
Old 05-31-2010, 11:31 PM   #4
EFB055
~sp33~'s Avatar
Isn't there a product called 'gasket remover'? Apply+scrape off.
~sp33~ is offline   Reply With Quote
Old 06-01-2010, 12:17 AM   #5
Crazy Honda Guy
Deetz's Avatar
Quote:
I haven't, is that what Honda dealers use?
Quote:
Not sure, that's why i am asking. I know all the "newer" head gaskets are metal, and so easy to deal with when changing over. I posted this one, because it was original, never been changed....the style that Honda went away from. It just leaves so much material behind apon removal after all of this time
Old 06-01-2010, 12:22 AM   #6
Crazy Honda Guy
Deetz's Avatar
The underside of the head had that junk all over it too, you might be able to see what i am talking about
Old 06-01-2010, 01:04 AM   #7
EFB055
~sp33~'s Avatar
Not all 'new' head gaskets are metal. Most that i know of are the same type as your engine had on there, when i did a HG on my Cressida i used that soft type. They have their advantages, for one they form a better seal if your mating surfaces aren't 100% true, which is often the case with old heads.
Old 06-01-2010, 12:34 PM   #8
D16SiHatch's Avatar
i tried using a gasket remover when i did an a6/y8 swap and it didn't work worth a ****. tried scraping at it, used a razor, nothing worked very efficiently and i had been at it for probably 2 hours.
then i got an idea and a buddy of mine lended me an angle air grinder with a fairly high grit pad. it worked awesome and took all the old material off real fast and left a nice finish for the new gasket to mate to. i know this method isn't recommended by some, but if you're careful and don't gouge the surface, or use to low grit of a pad, it should work fine.
i've also heard people say these work pretty well, but i haven't used one personally so i can't say. 3m roloc bristle pad i believe is what it's called
http://www.youtube.com/watch?v=2lM7IgqMAiA
D16SiHatch is offline   Reply With Quote
Old 06-01-2010, 02:48 PM   #9
Crazy Honda Guy
Deetz's Avatar
Wow, that's pretty cool. I'll look into that, thanks!
Old 06-01-2010, 03:45 PM   #10
lunalink's Avatar
D16 si hatch beat me too it lol.
lunalink is offline   Reply With Quote
Old 06-01-2010, 06:22 PM   #11
D16SiHatch's Avatar
shore thing man
Quote:
indeed i did :p
Old 06-01-2010, 07:13 PM   #12
1 Civic I's Avatar
Thats a nice find i wish i could find one for that cheap even a shell. must be 2nd coat of paint. handles are painted red? arnt they all black?
1 Civic I is offline   Reply With Quote
Old 06-01-2010, 07:54 PM   #13
Crazy Honda Guy
Deetz's Avatar
Quote:
Actually, here in Canada, "ALL" 1990 and 91 Civic and crx Si models came with both painted mirrors and door handles. ALL EF's in Canada also have pillar mounted seat belts too
Old 06-02-2010, 05:29 AM   #14
sde780's Avatar
nice pickup
I used a razorblade on mine, little by little. But it came out clean
sde780 is offline   Reply With Quote
Old 06-02-2010, 12:38 PM   #15
BrayzieEF9's Avatar
not sure if the dealers uses razor blades to removed em,but thats what me and my buddies use,its like the same concept of removing stickers off your window with a razor blade
Old 06-02-2010, 12:53 PM   #16
D16SiHatch's Avatar
razor blades not only suck to use, but you run the risk of nicking the block. using the angle air tool allows you to achieve a nice even surface, not to mention it takes a hell of a lot less time.
Old 06-02-2010, 01:01 PM   #17
BrayzieEF9's Avatar
yeah thats true,but not everybody can afford air tools though.
Old 06-02-2010, 01:04 PM   #18
ewwww gross!
jbmmfrie is offline   Reply With Quote
FS/FT CTR RIMS,PLM SMSP REP HEADERS,RC INJECTORS,TURBO KIT,INTEGRA PARTS Dc4LsTeG Southern California (Sales) 39 03-29-2012 06:49 PM
2011 Project- RHD CR-X Del Sol from Japan Deetz Appearance Build Threads 21 03-15-2011 07:45 PM
ITR head, M24x cams, +more hondalifestyle29 Northwest (Sales) 5 12-17-2010 01:56 AM
Seat swap- 05 into 02 RSX Deetz Acura RSX DC5 & Honda Civic EP3 0 10-10-2010 06:07 PM
HUGE PRICE DROP need it gone_ BUILT ITR HEAD +more hondalifestyle29 For Sale 5 06-16-2010 12:21 AM
Tags
1989, 1990, change, civic, cressida, crx, d16a6, gasket, head, honda, hondatech, metal, removal, tech, time, tru
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
