D15B2 performance parts - Honda-Tech
Old 02-13-2007, 10:21 AM   #1
02S-dime's Avatar
Default D15B2 performance parts
I am looking into buying a '89 Civic Hatch with a D15B2 in it, it already has an intake, header back full exhaust, slight drop, short-throw shifter, and ignition upgrades, I was just wondering what else is out there performance wise for this engine short of doing a Swap
02S-dime is offline   Reply With Quote
Old 02-13-2007, 10:22 AM   #2
MagnaniEG6's Avatar
Default Re: D15B2 performance parts (02S-dime)
there really isnt else you could do unless you go boost or do a mutlipoint swap
MagnaniEG6 is offline   Reply With Quote
Old 02-13-2007, 10:26 AM   #3
hondata151's Avatar
Default Re: D15B2 performance parts (MagnaniEG6)
yup
hondata151 is offline   Reply With Quote
Old 02-13-2007, 10:27 AM   #4
MagnaniEG6's Avatar
Default Re: D15B2 performance parts (hondata151)
Quote:
Originally Posted by hondata151
yup
king of the hill moment
Old 02-13-2007, 10:33 AM   #5
02S-dime's Avatar
no cams or anything that you can put in to make a little bit more power? and what kinda power gains would be seen from the MPI swap, and wheres a good place 2 get it (and average price and difficulty level)
Old 02-13-2007, 10:35 AM   #6
MagnaniEG6's Avatar
Quote:
Maybe you could get a custom grind cam. On the mutipoint swap I dont know how much more hp but if you never done any wiring or engine work it should be pretty hard. But once its converted to mutlipoint you could go troube easyier
Old 02-13-2007, 10:45 AM   #7
dr_latino999's Avatar
Since I'm such a nice person, I'll tell you the Horsepower gain --> You can expect to be running around 102 HP (Crank), or in other terms you'll turn your boring stock DPFI motor in a boring stock D15B7 with more power out of the next generation
dr_latino999 is offline   Reply With Quote
Old 02-13-2007, 10:47 AM   #8
02S-dime's Avatar
I read somewhere on the internet that a D16A6 cam can be put into the D15b2 but I don't always believe what I read.
Old 02-13-2007, 10:49 AM   #9
Yup, D15B2 Head = D15B7 Head = D16A6 Head = SOHC ZC Head, all the same casting.
Old 02-13-2007, 11:06 AM   #10
92civicfreak's Avatar
get your head decked ... hahahaha
92civicfreak is offline   Reply With Quote
Old 02-13-2007, 12:48 PM   #11
gibsanez's Avatar
Default Re: (92civicfreak)
higher c/r pistons and a tune plus a half decent cam. + mulitport.
gibsanez is offline   Reply With Quote
Old 02-13-2007, 12:54 PM   #12
Stouts 'n' Scotch
wiZCo's Avatar
yup
Tell you what man them dang ol n00bs man dunno bout no dang ol D15B2 slow'r en a dang ol slug man shoot. (Boomhauer moment). Yup.
wiZCo is offline   Reply With Quote
Old 02-13-2007, 01:03 PM   #13
janz3n's Avatar
Default Re: D15B2 performance parts (wiZCo)
iv read that if you put a d16a6 cam in a d15b2 you have to get a different timing belt.. not from a d16a6 but something els.. or maybe im crazy.. but anyways.. dont mess around with dpfi. swap in a mpfi (si) manifold . its day and night. plus you can drop in a better motor like a B series or dohc zc and not worry about wiring mpfi since you already did it. if you go with a b series vtec engine then all you need to wire is vtec.
janz3n is offline   Reply With Quote
Old 02-13-2007, 02:20 PM   #14
Default Re: D15B2 performance parts (janz3n)
Quote:
No you don't, myth killed before it started
Old 02-13-2007, 02:27 PM   #15
kyle h.'s Avatar
Default Re: D15B2 performance parts (dr_latino999)
you have to use a different cam gear. from a y series engine, d16y8, etc...
kyle h. is offline   Reply With Quote
Old 02-13-2007, 02:40 PM   #16
EFHATCHMAN's Avatar
Default Re: D15B2 performance parts (kyle h.)
FROM WHAT I UNDERSTAND, YOU CAN USE THE D16A6 CAM GEAR WITH THE CORRESPONDING CAM(SI). IM IN THE PROCESS OF DOING THE MPFI SWAP AND THATS WHAT I WAS TOLD.
GOOD LUCK WITH YOUR PROJECT
OH YEA, YOU'LL NEED THE PM6 ECU AS WELL!!
EFHATCHMAN is offline   Reply With Quote
Old 02-13-2007, 03:34 PM   #17
BlueRex1020's Avatar
Default Re: D15B2 performance parts (EFHATCHMAN)
or zc or ls ecu
BlueRex1020 is offline   Reply With Quote
Old 02-13-2007, 03:37 PM   #18
Quote:
Correct
Old 02-13-2007, 03:44 PM   #19
rayzian's Avatar
take out the secondary butterfly plate in the TB, it's held on by two screws and gives the intake a little more roar
rayzian is offline   Reply With Quote
Old 02-13-2007, 05:17 PM   #20
janz3n's Avatar
Default Re: (rayzian)
Quote:
and so it begins................
please dont take anything out of your TB. its there for a reason. plus you'll feel really stupid when you drop the screws in your intake.
ya thats what i was talking about^ thats what iv heard/read. dont know if its true.. dont really see why you wouldhave to use a different gear though..
Old 02-13-2007, 05:22 PM   #21
the butterfly plate is likely there to channel air flow, the factory put it there for a reason. Not for sound, if they were to muffle sound, theyd put baffles of some kind in the intake tubes. He's right, dont touch it, who wants roar anyways if youre not going fast.
betsy84 is offline   Reply With Quote
Old 02-13-2007, 05:45 PM   #22
bobbyg crxh22's Avatar
Default Re: (betsy84)
do a mpfi then
put a vtec head on it
then turbo cam and turbo
or go n/a
bobbyg crxh22 is offline   Reply With Quote
Old 02-13-2007, 07:21 PM   #23
kyle h.'s Avatar
Default Re: (janz3n)
you won't be able to get engine timing setup properly without it, due to the b2 crank rotation/indexing being different than the a6. simple mechanics.
Old 02-13-2007, 09:15 PM   #24
Default Re: (kyle h.)
sell your motor to a ricer and buy a better one.
Jonknee is offline   Reply With Quote
Old 02-13-2007, 09:54 PM   #25
ProjectDarkBlack's Avatar
Default Re: (Jonknee)
Quote:
ProjectDarkBlack is offline   Reply With Quote
D16Z6 head on a D15B7 block? Jmaxey27 Honda Civic / Del Sol (1992 - 2000) 2 06-11-2013 10:48 AM
Performance Head Parts for d15b2 memorybox Honda CRX / EF Civic (1988 - 1991) 4 06-23-2006 12:35 PM
D16A6 Cam swap w/ D15B7??? New Image Honda Civic / Del Sol (1992 - 2000) 13 02-06-2005 06:31 AM
Cam Gears ThaCivicAssassin Honda Civic / Del Sol (1992 - 2000) 9 09-03-2004 03:18 AM
Header for D15B7...Worth it? JMod Honda Civic / Del Sol (1992 - 2000) 10 02-04-2004 09:14 PM
Tags
aftermarket, build, d15b2, engine, honda, intakes, kit, motor, operformance, parts, performace, performance, preformance, proformace, rebuild
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
