D15B need help
D15B need help
Engine Bearings (Either from ACL or King)
+ Main Bearing Set (We have Standard and oversizes: .25mm = .010" or .50mm = .020")
+ Rod Bearing Set (We have Standard and oversizes: .25mm = .010" or .50mm = .020")
+ Thrush Washer
what one do i get??? the walls on the D15B are thin right????
+ Thrush Washer
Re: D15B need help
if i pull my engine almost all the way out i'll just ask the machine shop what ones so i wont need to do it. and i do not have a platiguage.
Re: D15B need help
apparently you have no idea how to rebuild an engine if you think the cylinder walls have to do with bearing sizes. look go to autozone or whateverthehell and get some plastigauge...you need to do this to measure the oil tolerances!! GOOGLE orrrr let someone else rebuild it??
Re: D15B need help
the kit is for my D15B so why do it?? if they are telling me the size of the pistons and the over size why measure it??? just sounds retarded to me to do it.
Re: D15B need help
do you have down syndrome or something?? the pistons have jack $hit to do with what bearing size you use. you clearly have no business putting an engine together you use a feeler gauge to measure the tolerances of the compression and oil control rings. plastigauge is used on the bearings, which you seem to be unaware, are located beneath the cylinder walls. they surround that heavy metal spinning lop-sided lookin thing.
Re: D15B need help
I got a d16a non vtec block, jdm version.im going to put a d15b head on it. Would it put oout more hp or would I be better off keeping the engine stock. as in d16a block with d16a non v head
EFB055
Re: D15B need help
What's JDM about a non vtec SOHC d16? Keep it stock, you're not going to get any more power out of putting a head with a smaller cam in it.
Re: D15B need help
well the fact that it was imported from japan comes to mind
http://www.jdmenginescorp.com/engine...d2-engine-only
Re: D15B need help
I MEAN REGARDLESS THE D15B HEAD IS also pretty strong. like the z6 apparently, so i mean. two jdm parts together. should = something better then stock non v . ill take some pics as i go along.
EFB055
Re: D15B need help
Aren't they the same casting? Just different cams and valves/valve springs?
I think you'll notice more difference just by using whatever engine/head combination is in the best condition.
bb4socal
02-01-2007 01:28 PM
