D15 build up
Re: D15 build up (blackEF)
the teg pitson will not work in the d15 due to wrist pin location. the y8 head with a stock d15 piston setup is the way to go. i had a stock d15 with the 6g nonvtec y7 head(wich is for sale) and it took zc powed crx all day long. its a great motor.
Re: D15 build up (WAFFLES)
i think so. and you can still get parts for it. unlike the zc. dont get me wrong i loved my zc but i was just surprized at the d15 power i got. this was the setup
d15 shorty
d16y7 non vtec head
clutchmaster stage one
d16a6 intake mani
d16y8 exaust mani with b20 down pipe
zcsi tranny
home made cai
thats it
i used the zc tranny on my d16z6/zc and the d15 and i still think the d15 was just as good as all of those. IMO
d15 shorty
d16y7 non vtec head
d16a6 intake mani
zcsi tranny
home made cai
thats it
Re: D15 build up (MIDNIGHT)
from what mista bones has said the piston set realy low in the cylinder and does little to nothing for comprision. and a flat top piston will always have a lower chance of ditonation campared to a dome
the y8 will give you a higher comp ratio than the y7 due to the square chambers and the vtec will give you a better top end. i just like the simple non vtec approch.
i guees i alway toss them in the trash our use them as a backup motor. but i would think it would be the same as a dx motor just with 2 valves reliefs on the piston wich mean you gotta swap out piston before you can put a 16v head on
Re: D15 build up (TorteX)
right now, i'm in the process of finishing my project. i got the d15 + y8 head (P&P, 3 angle vavle job, .40" milled head, y8 headgasket, d16a6 intake man+TB (match ported to head, CAI, Chikara torque step headers) i got everything for super cheap, and did all the machining(vavles,mill,P&P) myself at school, i'm pretty sure the d15 mini me will smoke alot of cars out there, problem is right now i got an automatic, but have the tranny ready to swap too, i'll let u know how it works out.
hey midnight i got a 90 dx with a d16 bottom and a d15 top!!! the car runs like **** (cut off at 3600rpm)and i think it is the injector!!! i clean the injector once and it ran good for a week but then it was the same again!!!o yea can u explain what car engine do i get those intake manifold and cams !!! i dont really know what cars and engine u get those item from!?
Re: D15 build up (igotcrx)
you cut out proplem could be a couple of things. i need more info. as for the parts use pgmi intake manafold from a 88-2000 d16 motor
car cut off at 3800rpm ever gear!!! when i took off the injectors and clean it,it ran find for 2 weeks (cut off at 7500rpm) and it start all over again!!! it have a 1.6 bottom w/ 1.5 dx heads and the rest... i have stock dx ecu on it now
*Boostwerks*
05-01-2003 02:22 PM
