cv-joint replacement.
How do you replace the hub side cv-joint or any diagrams showing the parts that make the cv-joint cos I now know someone who can get honda built parts.
I dont need to replace the whole shaft cos it's just been rebuilt but they used all honda built parts apart from the hub side cv bearing.
Re: cv-joint replacement.
You mean the boot or the actual joint? The part cost for the OEM joint parts will probably cost way more than a remanufactured axle. Axles are a pain in the *** to take apart, not really worth it.
Re: cv-joint replacement. (FourthGenHatch)
I mean the joint.
I can get the parts for the job cheep and there honda parts not aftermaket s**t.
dont want to use refab shafts cos i had them abd they lasted less then 2 months after run turbo & being in the uk there aint a lot of poeple who make uprated shafts for honda's so honda stuffs the best I can get and the cheepest.
threes
Re: cv-joint replacement. (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm »</TD></TR><TR><TD CLASS="quote">After you take the boot off, it kinda falls apart, pretty self explanatory.</TD></TR></TABLE>
this is false. the joint does not just fall apart. the outer race will come off the axle easily, but then inner ball and cage assembly comes off by taking off a snap ring. get the haynes manual. its cheap and tells you exactily what to do.
i have assembled many a joint, and have been very satisfied with the end results. i suggest you make your own joints so you can keep on rollin
Re: cv-joint replacement. (c jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson »</TD></TR><TR><TD CLASS="quote">
i have assembled many a joint, and have been very satisfied with the end results. i suggest you make your own joints so you can keep on rollin </TD></TR></TABLE>
Thank mate
Thats what I was after.
I plane to recon all my own joints from now on.
but i didn't think they made a haynes manual for the 91 crx??
Thank mate
Re: cv-joint replacement. (NOSED_CRX_VTEC)
C jackson is exactly right except get the chiltons manual- I bought the haynes too and it blows). The Chiltyon Manuual covers the 84-95 civ/crx/delsol. It's for us models anyway. Try http://www.icleord.net/honda this guy has a crx factory manual scanned into his computer.
threes
Re: cv-joint replacement. (cstem)
ya the haynes manual blows, but it only cost like 13 bucks. i got one a looong time ago when i first bought my car, had perfect instructions for rebuilding the axles.
Location: I told you to wait in the truck in Texas, United States
For a diagram,Go here: http://www.binghamtonlife.com/...s.htm
If Honda axles are the same as Toyota ones (and they look like they would be) basically all you do is the inboard joint isn't really held in with anything. Take off the retaining ring and pull the joint apart, it is just held together by its inability to pull apart because of the suspension. You have to take out 2 snap rings than bang the joint off of the splines and pull that boot off and replace if needed. Same thing for the other side.
threes
Re: cv-joint replacement. (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">Helms doesnt cover outboard joint disassembly, which they are talking about. in fact it says dont even try. </TD></TR></TABLE>
lol dont even try. how retarded is that. a service manual that says you shouldnt do this or that.
lol dont even try. how retarded is that. a service manual that says you shouldnt do this or that. </TD></TR></TABLE>
And how many of you lot do what the service manual says
c-joint replacement. (NOSED_CRX_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOSED_CRX_VTEC »</TD></TR><TR><TD CLASS="quote">
And how many of you lot do what the service manual says </TD></TR></TABLE>
Re: cv-joint replacement. (88DXCRX)
Thank you so much for the cv joint link......it's perfect. I will be doing this soon, to my little 89' HF. She just went over 200,000!!
Renee
Renee
-Jon
-Jon
