CRX Sir Front sway bar size?
I need to replace the bushings on my front sway bar. Does anyone know what size the ef8 front sway bar is?
Re: CRX Sir Front sway bar size?
btw, whats the code printed in the middle of the swaybar? it should also be embossed on the side of the bushings.
can you get a caliper and verify its diameter since you have it in your hands?
you can also ask the uk crx forum.
http://board.hondacrx.co.uk/phpBB2/index.php
i lost my account info and dont feel like registering a fake account just to contact the admins.
The bushing has a letter F on it. Also i can grab the sway bar and move it 1/2 to 3/4's of an inch, is that normal? Im having issue's with my shift linkage rubbing the sway bar and making it hard to shift.
No, its not normal to move a swaybar.... At all.
What's the deal with your car? Did you add all the front end parts from a SiR on to a US spec crx?
Thanks for the F info, good to know. looks like it IS 19mm. shares the same bushing as the sedans which i know is 19mm, but they are NOT the same swaybar.... the ends are completely different.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/sway-bar-sizes-1894834/
https://honda-tech.com/forums/showthread.php?t=1894834
The 19mm Civic Sedan front sway bar will still fit on a US CRX, though, correct?
