Crx non A/C set up question
Re: Crx non A/C set up question (92integracer)
It should be #29 in this diagram - note that this one is for a 1990 CRX Si.
https://www.hondapartsdeals.co...7.gif
I can't make the image hotlink...
P/N 79810-SH3-A01
I'm hitting a junkyard today to look for a used one. It's the same in the 90-91 non/AC Hatch as well.
P/N 79810-SH3-A01
Re: Crx non A/C set up question (CoryB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoryB »</TD></TR><TR><TD CLASS="quote">It should be #29 in this diagram - note that this one is for a 1990 CRX Si.
P/N 79810-SH3-A01
I'm hitting a junkyard today to look for a used one. It's the same in the 90-91 non/AC Hatch as well.</TD></TR></TABLE>
That is it. I have them in all of my CRX's.
P/N 79810-SH3-A01
Re: Crx non A/C set up question (CRX Toad)
what is the advantage of using this part in a crx with no a/c?
(i understand that this replaces the evaporator.)
weight reduction? more efficient air flow?
Re: Crx non A/C set up question (gringo7718)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringo7718 »</TD></TR><TR><TD CLASS="quote">weight reduction? more efficient air flow?</TD></TR></TABLE>
I only had one of my CRX's that came with A/C, so my bypass tubes were already in there from the factory.
well yeah a little weight reduction, but if you take out you a/c completely then without the evaporator or replacement then i don't think you can use your heat.
Re: (92integracer)
no heat! HAHAHA
i live in so. florida so i have plenty of heat --- i dont have the heater core even hooked up. i removed my compressor, condenser, and the lines. i left the dash intact with the hope and dream that one day i will have A/C.
downtime1
11-24-2006 10:27 AM
