CRX key question
Old 06-29-2006, 06:59 PM
VegasEFHB's Avatar
Default CRX key question
I am purchasing a 91 CRX HF, but the keys for the doors and hatch locks are missing. We have the ignition key as the ignition lock was replaced due to a theif destroying the previous before the last owner purchased the car, but we can not find the OEM keys for the outer locks. Does anybody know if a Honda dealer can get this done for me? Should I bypass the dealer and have a private locksmith do it for me? Is it even possible for a locksmith to make new keys for an existing car lock without a reference key? Thanks in advance guys, I really appreciate your help!
Old 06-30-2006, 01:26 AM
VegasEFHB's Avatar
Default Re: CRX key question (VegasEFHB)
Does anybody have an idea? I have to get this done ASAP so the car will pass inspection.
Old 06-30-2006, 02:44 AM
JJ's civic's Avatar
go to a junkyard find sum older honda and acura keys and try them. one or two should work. or even try the key you have.
Old 06-30-2006, 06:36 AM
rsca_crx's Avatar
go to the dealer with id and proof of ownership, and your vin#. they'll cut you new keys for 3 bucks a pop.
Old 06-30-2006, 07:03 AM
thesmogman's Avatar
A locksmith should be able to re-key the doors and hatch to the ignition key.
More than $3 bucks though. However you would have to have two keys this way.
Old 06-30-2006, 07:28 AM
Tippyman's Avatar
Default Re: CRX key question (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">However you would have to have two keys this way.</TD></TR></TABLE>
Two keys = better theft prevention!
man2mal's Avatar
Default Re: CRX key question (joeny12985)
Pull pass. side door panel off, take bolts (2) out of exterior door latch, remove retainer, remove tumbler, take stamped code on tumbler into dealer, they can grind you a key to fit all your exterior locks by that code ( prvided that they are still all the same).
Old 06-30-2006, 08:33 AM
blumpfish's Avatar
Default Re: CRX key question (man2mal)
The dealership should be able to make keys for you, just bring the VIN number and registration or title i can't remmeber which.. but i called 2 different dealerships around here when i needed keys, one charged 8$ one charged 5$ .. its cheap
Old 06-30-2006, 10:18 AM
rsca_crx's Avatar
Default Re: CRX key question (blumpfish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blumpfish &raquo;</TD></TR><TR><TD CLASS="quote">The dealership should be able to make keys for you, just bring the VIN number and registration or title i can't remmeber which.. but i called 2 different dealerships around here when i needed keys, one charged 8$ one charged 5$ .. its cheap</TD></TR></TABLE>
vin, something with the vin and your name on it, and a photo id. mine, like i said above was 3 each.
anything else is a gigantic waste of time and money.
the only reason you'd ever have to take the lock out to read the numbers on it is if you have different locks than what came with your car (like your ignition).
Old 07-02-2006, 11:16 AM
VegasEFHB's Avatar
Default Re: CRX key question (rsca_crx)
This is awesome guys, I didn't realize it would be so cheap! I will definitely get this done at the dealer ASAP.
Old 07-02-2006, 11:27 AM
silentdork818's Avatar
I heard new Honda blanks cost like $50...maybe i heard wrong.
Old 07-02-2006, 01:25 PM
Burlyirishdude's Avatar
Default Re: CRX key question (silentdork818)
yeah the newer keys can cost up to that much. **** the VW and merdeceds keys cost 200 to have recut with the laser. But the older keys cost like 6$ and then another 3$ to have cut for you. All my keys say honda, it's nice. I even had them order me the nsx key but write crx on the side. It's all silver red writing to match the rio red, and it's my master key for my crx. I know it sounds stupid, and it was, but i was 16 and just bought the car. Now i have my good ole plastic black key.
Old 07-02-2006, 06:28 PM
CASTUDILLO01's Avatar
might get the key code with the vin# if not call a lock smith
Old 07-02-2006, 06:33 PM
dr_latino999's Avatar
Default Re: CRX key question (CASTUDILLO01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CASTUDILLO01 &raquo;</TD></TR><TR><TD CLASS="quote">might get the key code with the vin# if not call a lock smith</TD></TR></TABLE> Will get the key code, cost me exactly 9$ at my local dealer. Exactly 6$ for the blank and 3$ for the cut.
Old 07-02-2006, 06:52 PM
91rexman's Avatar
also to answer the other question a decent locksmith can cut a key for the doors without anything to go by...they had to do it for us at the pri show in fl when we lost the keys to our truck
Old 07-02-2006, 06:58 PM
I tell doctors what to do
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">go to the dealer with id and proof of ownership, and your vin#. they'll cut you new keys for 3 bucks a pop. </TD></TR></TABLE>i work for a parts department, we don't even have to charge for looking up the key code but sometimes we do. i usually just charge the price of the key
RACERX72
11-08-2008 04:12 PM
p3t3rxp4n
05-08-2006 01:48 PM
civicshowracing65
11-03-2004 07:36 PM
shaddr3
04-06-2004 07:01 AM
jondancer
06-01-2003 09:12 AM
Quick Reply: CRX key question
