CRX GURUs: How do you remove steering from rear crossmember????
the rear motor mount on my 91 crx got damaged and tore out a piece of the crossmember that it bolts to. I want to remove that crossmember and replace it with one I plan on pulling from a friend's parts crx but I've gotten all the bolts undone (that seem to be holding the crossmember up), and it seems like the steering stuff goes through the crossmember. The steering stuff that I'm guessing goes all the way up to the steering wheel is holding everything from falling. Is there some way to get that separated???
I really need your guys help... Once I get the rear crossmember removed, I can start trying to install the B18C1 w/ JRSC!!!! Thanks a lot, guys.
Zack
Zack
Re: CRX GURUs: How do you remove steering from rear crossmember???? (88DXCRX)
If its not in the FAQ forum for crx's then I know for sure its in the 92-95 eg/ek forum, go there and look in the FAQ forum, as long as its not power steering then its basically all the same. PS it has pics too
https://honda-tech.com/zerothread?id=572765
I was bored so there you go!
