Start but no run, need help please!!!
Old 01-19-2013, 12:32 PM
Luke 91 ef's Avatar
Icon6 Start but no run, need help please!!!
Okay I have a 91 ef with a d16zc dohc. It started to take a bunch of cranking to get it started and then id be driving down the road and itll start bogging real bad off idle. I replaed the fuel pump and now itll start and shut off after two seconds. Is it a fuel pressure regulator or fuel filter maybe. Relay? Any have experience with this??
Old 01-19-2013, 02:40 PM
Former User's Avatar
Default Re: Start but no run, need help please!!!
New swap or has it been running well until recently?
CEL codes?
Check whether there is bright white spark at all 4 spark plugs.
Check whether all 4 injectors spray/pulse fuel.
Check the mechanical timing.
Old 01-24-2013, 12:57 AM
swordofdoom's Avatar
Check your main relay mine was having the same problems until one day it just never started again after cranks and cranks. If the main relay doesn't click when you put it to on its the culprit.
Old 01-24-2013, 09:36 AM
Luke 91 ef's Avatar
I turn the key, relay clicks, fuel pump primes, it might fire on two or three cylinders but wont fire up. It eventually fired up yesterday but today it doesnt want to. This is really wierd and is a serious problem
Old 01-24-2013, 09:40 AM
EfyourK's Avatar
Check fuel injectors an fuel pressure regulator man.. sounds like a fuel problem by the way your a stating your problems. Good luck!
Old 01-24-2013, 09:53 AM
It might help if you answered the questions directed at you.
Old 01-24-2013, 10:35 AM
Luke 91 ef's Avatar
Sorry, Its been swaped in for a few years, I bought the car and it ran great.
Spark is bright blue.
Old 01-24-2013, 10:40 AM
Spark should be bright white - test the coil and igniter unit.
CEL codes? All 4 injectors spray/pulse fuel? Mechanical timing correct?
95PreludeNAed
01-10-2012 04:09 PM
aunib.76
09-30-2008 01:58 PM
allmotor2.1
11-24-2007 04:52 AM
jdm_eg
21
09-07-2004 06:49 AM
drvfast
05-26-2004 08:29 PM
Quick Reply: Start but no run, need help please!!!
