crx dash removal ??????
Old 10-18-2007, 05:23 AM
89crxhf's Avatar
Default crx dash removal ??????
i have searched the archives and the faq and could not find a step by step dash removal guide. are there any? i need to remove my dash to get to my dash harness so i can fix it, any help would be appreciated.
Thanks Tom
Old 10-18-2007, 08:28 AM
SETI20's Avatar
Take off steering wheel.
Remove gauge cluster.
Remove glove compartment.
Temove center console.
Remove bolts.
There's one on top, in the middle of your dash. There are 2 on the far side. You have to remove the small vents.
There's one next to the hood popping lever. And some behind the glove compartment.
The last one is right in the middle of the metal structure holding the heater controls.
Old 10-18-2007, 08:53 AM
jacoop86's Avatar
Default Re: (SETI20)
when i took out my dash i just lowered the steering column instead of taking off the steering wheel. behind the wheel, on the bottom side of the steering column there is 2 bolts, take those off and lower the entire column so you dont have to mess with the controls (light switch and turn signal)
Old 10-18-2007, 08:56 AM
cone junkie's Avatar
Default Re: crx dash removal ?????? (89crxhf)
found this in the faq:
*UK Honda OFFICIAL Online Workshop Manuals (DOHC ZC included)
step by step is here in the pdf: http://media.honda.co.uk/car/o...flv=9
Old 01-03-2008, 05:11 PM
JRZ88DX's Avatar
bump for usefull-ness
Old 01-04-2008, 02:01 PM
snowseeker's Avatar
Default Re: crx dash removal ?????? (JRZ88DX)
You don't have to pull the gauge cluster. Just unplug the plugs from the fuse box. Lower the steering colume, pull off the radio shroud, pull the bolts out on the pass. and driver side. Pull the bolt out under the radio, pull the bolt out up by the windshield, unhook the cold air vent cable thingy on the drivers side, unbolt the ground wire by the steering colume and pull the dash out. It should look like this when you get it out:
Old 01-04-2008, 02:33 PM
wickedEFguy's Avatar
Don't forget to unscrew the climate control or you'll ruin it!
Old 01-04-2008, 02:46 PM
snowseeker's Avatar
Default Re: (wickedEFguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget to unscrew the climate control or you'll ruin it!</TD></TR></TABLE>
Yup, I just assume all crx climate controls are already expletiveed.
Old 01-04-2008, 04:31 PM
JRZ88DX's Avatar
Default Re: (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">
Yup, I just assume all crx climate controls are already expletiveed. </TD></TR></TABLE>
is that somehting that normally goes wrong with CRXs?
Old 01-04-2008, 04:43 PM
JapJunkie's Avatar
Default Re: (JRZ88DX)
You should be able to accomplish this task with the info. in this thread already.
Old 01-04-2008, 04:48 PM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRZ88DX &raquo;</TD></TR><TR><TD CLASS="quote">
is that somehting that normally goes wrong with CRXs?</TD></TR></TABLE>
More comon than the ripped seat bolster.
Old 10-02-2012, 02:40 PM
Bongman's Avatar
Ty just got my dash out. The climate control crumbled. I need one out of my CarDaver before it gets crushed. Working on the chassis I got from Kevin if you follow the IceyCRX K thread with 72 pages.
Thanks for the info. G.
Old 10-07-2012, 09:18 PM
Grover Edmonds's Avatar
Great links
wannab20hatch
03-03-2006 02:01 PM
Honda97
03-03-2005 11:47 PM
intezn
01-28-2003 07:16 PM
bbmoto
05-22-2002 12:13 AM
projectcrx
04-26-2002 04:25 AM
Quick Reply: crx dash removal ??????
