crx camber kit problems
Old 07-25-2004, 09:50 PM
AKEFVTEC's Avatar
Default crx camber kit problems
i gotta 88 crx with H&R 1 inch drop oe sport springs and koni yellows. I installed a set of Ingalls adjustable camber kit for the front tires myself a bout 4 months ago because i didnt want any premature tire wear due to negative camber. but now i have camber wear. could the tire wear be due to me not getting the car to an alignment shop to adjust toe or caster before or after i installed the kit???
Old 07-25-2004, 10:04 PM
Skitals's Avatar
Default Re: crx camber kit problems (AKEFVTEC)
I would bet you WOULDNT have uneven wear if you DIDNT install the camber kit and not get it all properly adjusted and aligned. Besides, you dont really need a camber kit with that set up. I have two crxs... one with the exact same shocks/springs as you. No camber kit. Other crx is even lower on tokico blue and gc coilovers... no camber kit, and no uneven wear.
Old 07-25-2004, 10:07 PM
michael O's Avatar
Default Re: crx camber kit problems (Skitals)
yes. Go have your car aligned now.
Arbiter
Suspension & Brakes
11-13-2007 03:32 PM
donger
01-30-2006 01:10 PM
Deo
12
09-15-2005 09:49 AM
AKEFVTEC
07-31-2004 12:35 PM
DJ:A
12-20-2001 03:02 AM
Quick Reply: crx camber kit problems
