CRX + b18c1 + 94 integra axles work?
I can purchase a GSR longblock from a local guy, and he also has the axles from the 94 integra. Can I use these on my CRX or do I need 90-93?
Re: CRX + b18c1 + 94 integra axles work? (nicks_jdmstyle_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 »</TD></TR><TR><TD CLASS="quote">nope 94's will not work, 90-93 are fine</TD></TR></TABLE>
If he has the 94+ intermediate shaft (halfshaft), he can use the 94+ axles. I have them on my CRX with a b18c. Just make sure you have the 94+ axle seals if you are using those axles so they seal up against the transmission correctly.
1 Post
Re: CRX + b18c1 + 94 integra axles work? (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">
If he has the 94+ intermediate shaft (halfshaft), he can use the 94+ axles. I have them on my CRX with a b18c. Just make sure you have the 94+ axle seals if you are using those axles so they seal up against the transmission correctly. </TD></TR></TABLE>
Correct
Passanger axles from 90-01 I believe are all the same drivers side needs to match the mid shaft and the axles seal needs to match also
Correct
Re: CRX + b18c1 + 94 integra axles work? (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">
Correct
Passanger axles from 90-01 I believe are all the same drivers side needs to match the mid shaft and the axles seal needs to match also </TD></TR></TABLE>
That's how I've done 'em.
In hind sight maybe the DA axles are the better idea because aren't the axles the same left and right? You could keep one axle in your garage in case you broke one and it would fit either side, unlike the 94+ axles.
Either way will work though as long as you have the correct intermediate shaft and seals.
Correct
1 Post
Re: CRX + b18c1 + 94 integra axles work? (JohnnieChimpo)
Axles are not the same lefte and right look at the inner splines the one that goes into the tranny has splines only about 1/2 way where the one that goes into the midshaft has splines the full length
My GFs lil bros car when we bought it had them switch and we didn't know it, the drivers side axles snapped a month later because the it only sits halfway in
Agreed.
Agreed.
lilpastrana
09-06-2007 07:30 AM
Si-Yaaa!
05-10-2003 05:02 PM
