Continuous blinks from ECU
Old 01-24-2010, 02:51 PM
My_EFsedan's Avatar
Default Continuous blinks from ECU
my moms car is an 89 civic sedan Automatic. sometimes it starts sometimes it doesnt. ive changed the main relay but that doesnt help. this has been going on since the car was bought last year.
today i tried to on work it. cranked it and now it just doesnt start. then a check engine light comes on. so i lean over to check it and never before have i seen 16 continuous blinks.
i mean it does:
. . . . . . . . . . . . . . . . = 16 singles
usually it would be:
... . = 1 solid and 1 single would be 16, fuel injector..
what does the 16 singles mean? i know it isnt code 1 cause theres no pause and only pauses after 16 singles and starts it again.
but if it is code 16, how would i go about fixing that?
Old 01-24-2010, 03:31 PM
Eighty-Nyne's Avatar
Default Re: Continuous blinks from ECU
Do you have a spare pm6, pm5?
Old 01-24-2010, 03:39 PM
My_EFsedan's Avatar
i have a pm6..
will that work for an automatic?
Old 01-24-2010, 03:47 PM
frank_el_tanke's Avatar
i'm guessing your mom's car is dual point because it's an 1989. if that's the case, then the pm6 won't work or won't work properly.
btw code 16 is for the fuel injectors. check to see if they're getting the proper voltage.
Old 01-24-2010, 04:03 PM
My_EFsedan's Avatar
yes its dual point. i dont have a voltage meter...
Old 01-24-2010, 04:07 PM
sde780's Avatar
$3 at harbour freight
Old 01-24-2010, 04:20 PM
My_EFsedan's Avatar
my mom needs the car tomorrow at 6am..
Old 01-24-2010, 04:29 PM
crx_si-r's Avatar
Swap the original ecu back in
Old 01-24-2010, 04:30 PM
My_EFsedan's Avatar
?? i never swapped the ecus..
Old 01-24-2010, 05:37 PM
The pm6 won't work if it's dual point. If you had a pm5 you could start and run the car but it wouldnt have the automatic kick down so it wouldn't drive. But it would test so see if the ECU is fried
Old 01-25-2010, 06:04 AM
jlicrx's Avatar
OBD0 D-series ECUs don't have long and short flashes, only short - 16 flashes is code 16 for fuel injector - not uncommon on DPFI engines - probably needs one or both fuel injectors replaced
Old 01-25-2010, 12:04 PM
sde780's Avatar
you sure? long flash = 10 short flash = 1 at least that's how it was with my EF sedan
Old 01-25-2010, 12:18 PM
Keyboard Humorist
4drEF's Avatar
Maybe unplug your O2 sensor and see if anything changes. Maybe it's just kicking out O2 sensor code over and over (one short blink)
rolledthatho
12-16-2011 12:09 PM
{EF9} GrEaZe m0nKeY
08-12-2009 09:26 PM
NATEDEEZY
01-06-2008 11:13 AM
theharlequin
04-13-2004 03:23 PM
AGPSuperstar
09-14-2003 04:32 PM
Quick Reply: Continuous blinks from ECU
