code 17 help
Old 11-05-2008, 10:19 PM
kenlrw39's Avatar
Default code 17 help
i have a b18a1 runing a b16 cable tranny and a obd0 ecu i keep getting a code 17 and know it's the vss code my speedo cable is fine what else could give me this code?
Old 11-05-2008, 10:25 PM
I heart My EF Sedan's Avatar
Default Re: code 17 help (kenlrw39)
maybe the ecu is not getting the vss signal from the gauge cluster?
Old 11-15-2008, 01:04 AM
424racer's Avatar
Default Re: code 17 help (I heart My EF Sedan)
maybe your getting a differnt code...
like 1, 10 , 7....
maybe...
good luck.
Old 11-15-2008, 09:59 AM
crx_si-r's Avatar
Default Re: code 17 help (424racer)
my buddies car did the same thing, 89 crx with b18a1. and to fix it we swapped out his gauge cluster, and the CEL went away.
Old 11-15-2008, 10:35 AM
uberEFtuner's Avatar
I assume your speedometer is showing a speed. But its probably wrong. If so...
I will tell you I have seen that problem before. You need to swap out the whole speedo cable assembly on the trans. The gears on speedo assembly on the B18 trans spin faster or slower than the gears from the original trans. So if you put the old assembly on the B18 trans it should work.
EF9 JAMS!!!
12-10-2006 10:26 AM
HT Chaplain
10-25-2006 08:26 PM
MattsHatch93
01-10-2006 06:23 PM
90AcuraIntegra04
08-07-2005 05:04 PM
Joebroni
05-29-2005 12:43 PM
Quick Reply: code 17 help
