clutch not going into gear - Honda-Tech
Old 03-17-2008, 09:37 AM   #1
krystne89's Avatar
Default clutch not going into gear
i have a 89 honda civic dx. I went to go somewhere this morning and the car started, I backed out of the driveway and started to go onto the street and it wouldnt go. while the car was on I couldn't get it to go into any gear not even reverse. with the car off I could put it in gear but it wouldnt start. with the car on I finally got it to go into reverse and the car died. I am hoping it is something that can be simple to fix. Any help is greatly appreciated.
krystne89 is offline   Reply With Quote
Old 03-18-2008, 10:36 PM   #2
89GSRHATCH's Avatar
Default Re: clutch not going into gear (krystne89)
check to make sure the clutch cable isnt broken or not ajusted right if it is ok its time for a clutch
89GSRHATCH is offline   Reply With Quote
Old 03-18-2008, 11:16 PM   #3
redwards's Avatar
check your axles to make sure they didnt pop out of the tranny, make sure the cv joints are still in one piece i remember one of my axles cv was just destroyed and would just spin and the other side of the same axle in the spindle would be motionless, and also check your axle nuts, loose axles nuts can cause that too.... i dont know about the stalling though....
redwards is offline   Reply With Quote
Old 03-19-2008, 11:19 AM   #4
krystne89's Avatar
ive got brand new axles put in last year..we checked the fluid level and needed to add more fluid. it goes into gear now but it is making a rattling noise.
Old 03-19-2008, 12:56 PM   #5
primetimeracing's Avatar
fluid??? what kind of motor is in that..it sould be a cable clutch...i dk
primetimeracing is offline   Reply With Quote
Old 03-19-2008, 07:14 PM   #6
What motor do you have in it? Have you taken the transmission off or messed with the flywheel? Is it stick or auto? It sounds to me that your flywheel may be loose, if you hear a grinding/rattling noise it's your flywheel bolts grinding up against your clutch.
91_Civic_Hatch is offline   Reply With Quote
Old 03-19-2008, 10:58 PM   #7
89GSRHATCH's Avatar
Default Re: clutch not going into gear (91_Civic_Hatch)
I thought your car was an ef i dident know you had a hydrolic tranny or i would have told you to check the slave cylinder and the clutch master cylinder
Old 03-19-2008, 11:41 PM   #8
DailyDriverCivic's Avatar
Sounds like a pressure plate problem if it happened all at once. If it was gradual I would guess clutch cable.
DailyDriverCivic is offline   Reply With Quote
Old 03-19-2008, 11:44 PM   #9
Hanmin's Avatar
Broken pedal bracket, go down there and check the bracket. Same thing happened to me and alot of people here.
Hanmin is offline   Reply With Quote
Old 03-19-2008, 11:54 PM   #10
Fo-Do Fanatic's Avatar
Default Re: (Hanmin)
(if you have a hydro tranny) first things first. check your clutch master to see if you have fluid. if you do, is there any fluid leaking on the driver side floor board right by the piston on the clutch pedal? if not then bleed the clutch through the slave cylinder...see if you get any air bubbles out of it. if that doesn't fix it. my guess would be one of two things i have done. bent my clutch fork and wouldn't go into any gear without grinding and i had my pressure plate seize to my clutch disk.
cable clutch....check and see if the cable is either stretched or broken or just not adjusted properly. if thats not it. like i said before clutch problems...or check your flywheel bolts if you here any grinding while in gear..
also try putting your car into reverse of first while the car is OFF, and then start and drive it in that gear.
tell me what happens.
GL.
Fo-Do Fanatic is offline   Reply With Quote
Old 03-20-2008, 12:11 AM   #11
Quote:
That is a good point as well. I had to repair the manual pedal cluster that I swapped into my EF (Auto to manual swap), it was cracked around the clutch pedal pivot point, and was tweaked pretty bad.
Old 03-20-2008, 06:15 PM   #12
krystne89's Avatar
Default Re: (DailyDriverCivic)
i have a clutch cable...should have mentioned that. in my honda book it said to check the transaxle fluid and when we did he put more in but I dont think it was enough. My car starts and the next day it went into gear like 10 different times. The following day it wouldnt go into gear. I have tried to start it in gear and it will turn over but not start. That day it was going into gear I could hear a rattling and when I pressed on the clutch the rattling stopped. I do not hear the rattling now.
Old 03-20-2008, 06:44 PM   #13
89civicdx's Avatar
Default Re: (krystne89)
hi I bet it's your pressure plate springs.
If you turn it off stick it in gear and give it gas with the cltuch in..... it should start/run but then you shouldn't be able to get it out of gear....untill you turn it off.
89civicdx is offline   Reply With Quote
Old 03-20-2008, 09:55 PM   #14
Default Re: (89civicdx)
sounds like your pressure plate springs are toast...when you start your car does your car jump like its in gear?
Old 03-21-2008, 11:42 AM   #15
krystne89's Avatar
ok now my uncle checked it and we didnt put enough fluid in. he drove it, then i drove it when i got back home i left the engine running cause now it sounds like i got a vacuum leak...i tried to put it back in gear and it wouldnt go. my uncle checked a few things got in the car and it went into gear. is something sticking or not engaging?
Old 03-21-2008, 11:46 AM   #16
a cable clutch doesn't have clutch fluid.... nor a slave cylinder. nor a master cylinder... have you checked your clutch cable?
Old 03-21-2008, 10:37 PM   #17
89GSRHATCH's Avatar
Default Re: clutch not going into gear (Fo-Do Fanatic)
thats what iam saying so is your car and ef or not you keep saying you put more fluid but if you have a 89 civic then there is no fluid its a cable are you adding tranny fluid is that what you are adding ????????????
Old 03-21-2008, 10:40 PM   #18
89GSRHATCH's Avatar
Default Re: clutch not going into gear (89GSRHATCH)
check if the clutch cable is adjusted right
Old 03-22-2008, 12:48 AM   #19
krystne89's Avatar
awwhhhh it was a piece of metal that broke off the clutch plate. so the whole thing was replaced. thanks guys.....
Old 03-23-2008, 03:30 AM   #20
so the springs on the pressure plate or the actual clutch disc itself broke? what clutch did you replace it with?
91 SI tranny wont shift in reverse StayTunedEf Honda CRX / EF Civic (1988 - 1991) 3 10-24-2012 11:26 AM
93 civic si wont go into gear young-gun92eg Tech / Misc 2 06-16-2012 10:10 AM
93 civic si won go into gear young-gun92eg Transmission & Drivetrain 0 06-13-2012 12:11 PM
ls tranny question ? T Thrash 09 Honda Civic / Del Sol (1992 - 2000) 4 08-28-2010 05:57 AM
HELP!!! CAR ISNT SHIFTING RIGHT dc2gsr96 Acura Integra 5 04-25-2006 10:17 PM
Tags
1989, 1991, 9000, 91, cable, checking, civic, clutch, eclipse, engaging, fix, fluid, gear, honda, reverse, saab
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
