Clutch kit for max reliability
hello guys,
It's 91 civic ef with d15b1 and 4 speed tranny. I am going to throw in a rebuild engine. I want to throw in a new clutch set as well. My goal is to get maxium reliability. I have a few questions regarding this topic:
1. EXEDY stage 1 clutch kit with flywheel a good option?
2. What about EXEDY pro kit compare to the stage1?
3. Would that be an overkill if I put on a stage2? And maybe it is going to sacrifice driveability?
4. I have seen a lot of clutch kit with new flywheel for about 100 bucks (XTR, PPC,etc). Are they worth trying?
5. I lean towrads kit with flywheel because resuracing flywheel will cost 30 bucks in my area...
6. Any other better options?
Keyboard Humorist
Re: Clutch kit for max reliability
stage 1 will be great for what you are doing.
Stage 2 is overkill and not really going to enhance your reliability unless you up your power level quite a bit.
$30 isn't bad for resurfacing. It is a lot less than what a replacement will cost you.
hello guys,
4. I lean towrads kit with flywheel because resuracing flywheel will cost 30 bucks in my area...
5. Any other better options?
I like the centerforce clutches. I have one on my D16, but haven't drove it in years. I don't remember it being bad. On my B18C it is amazing. I've never stalled, and I live in Pittsburgh.
I'm using one now with a 12 to 1 a6 with a cam and bolt ons. Thought about installing a stronger clutch when iput in an lsd trans last week...but decided why mess with what works.
While that compression ration really does exceed 'slightly modded' due to the work required, I really was aiming at the torque. How many ft-lbs does your engine make? I also do agree, no reason to mess with what is working. I have an exedy OE replacement on my CRX and it held P29s w/ Y8 head. I kept it when I swapped the pistons just recently.
I keep having money setbacks keeping me off the dyno. I need to get one of the dyno/acceleration apps and see what i can come up with. Compared to stock mybutt dyno says I'm making more power from 2500 to 7500 . if i can get something working i will post it. Wild *** guess says 120whp and 110 lb ft with at least 12 more hp possible with tuning...
That's well within the realm of stock-ish torque to me. I've seen some beastly A6's put down 100 ft-lbs with proper tuning and very mild mods. Still, it isn't a ton more torque compared to stock and the stock-ish clutches can handle it.
I have used an Exedy Stage 1 with 7lb Fidanza flywheel with my fully built B20 Vtec (250hp/160tq). I don't drag race, but I so time attack, autox, hillclimbs. This clutch was totally fine for all of that.
So your d15 will be absolutely fine with an OEM exedy or the stage 1.
-Intl Steve Krew
Clutch torque capacity needs to exceed the torque of the motor...take a look at some other people's specs that are comparable to yours to get an idea of where your torque numbers may land.
danny_civic97
03-03-2007 06:01 AM
spoon23_JDizM AkA SpOoN20
09-17-2004 04:34 PM
stackz
06-26-2003 03:08 AM
