Clutch Cable
Clutch Cable
Got A CRX With A Z6 Swap, Just Put A New Si Tranny In With Exedy Clutch, And I Have A DX Clutch Cable, Its Adjusted All The Way Tight And The Release Point Is Like Right Of The Floor, So Is There Any Other Clutch Cables That Are Shorter And Allow For More Adjustment
Keyboard Humorist
Re: Clutch Cable
There shouldn't be any difference from the DX to the Si (cable, right?) tranny as far as your clutch cable goes.
Sounds like something isn't hooked up correctly at the tranny - bracket, cable grommets, etc.
Re: Clutch Cable
do you have your clutch cable bracket on your motor, it makes a difference. I bought a zc swap last summer and fought my clutch cable for months before I realized the I had no brackets on this motor, the zc I got was an auto before I got it. Your cable could also be stretched if its an older cable but I dont know if there is a difference between dx and si... I would have to say no but thats just guessing.
Re: Clutch Cable
cable stretch.
buy some fat washers cut a notch in them and slip them in between the ajustment **** and the cable bracket.
that is if your cheap like me...
If not go buy a new cable
Re: Clutch Cable
yeah the clutch is broke in. i mean i think it may be stretched, im either gunna try modding my bracket to get more adjustment or just do the washer idea. thanks for the info.
Re: Clutch Cable
glad to help, I got some nylon washers from ace hardware that are pretty thick and just zipped a notch in the sides of them to slip them over the cable.
works great and was like 2 bucks
crex23
07-11-2009 07:36 PM
