DOHC VTEC head swap
Old 03-13-2004, 08:27 PM
macjr's Avatar
Default DOHC VTEC head swap
can u put a dohc vtec head on a d15. if so how? thx
Old 03-13-2004, 08:28 PM
Built B16A's Avatar
Location: hittin corners so hard you can taste my rims..
Default Re: DOHC VTEC head swap (macjr)
nope.. dont' bother trying.
Banned
LSVTEC 91 Civic's Avatar
No, B series won't bolt up to a D series.
You could probably go with a DOHC ZC head, not sure though.
Old 03-13-2004, 08:34 PM
macjr's Avatar
Default Re: DOHC VTEC head swap (LSVTEC 91 Civic)
what is a zc head exactly?
Old 03-13-2004, 09:27 PM
Built B16A's Avatar
im not sure exaclty what the engine ID is.. but its basicly a D series bottom end, wiht a LS non vtec head.
they were outside of the US.. mainly japan. do a ZC search.. ALOT of poeple have tem in CRX's.. its a straight swap.. no new mounts.. same tranny, linkage.. ECU.. just longblock.. mainly new engine with 2 cams.. can't beat it.
Old 03-13-2004, 09:31 PM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">You could probably go with a DOHC ZC head, not sure though.</TD></TR></TABLE>
nope, can't do that either! DOHC ZC heads only fit DOHC ZC blocks
If you're stuck on keeping the D15 bottom end, then a D16Z6 head is about the best one to use (SOHC VTEC) Do a search for "mini me" and you'll get info on this setup.
If you want DOHC VTEC, then you'll need to swap the entire engine.
Old 03-13-2004, 09:47 PM
Built B16A's Avatar
Default Re: DOHC VTEC head swap (thumpu77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">
If you want DOHC VTEC, then you'll need to swap the entire engine.</TD></TR></TABLE>
about what i was saying that ZC swap is increadably cheap.. i think the long block is like 5 bills, and thats all you need. no mounts, linkage, axels, ECU.. everything changes over.
but yes the ZC block is one of a kind.. but now.. dual and single cam heads, and blocks do not interchange.
however.. "minime" setups can convert, and of course the LS VTEC, and B20 VTEC, can be achived.
mymeatb18"
43
09-21-2019 12:14 AM
HondaHemi
09-04-2005 11:12 PM
CivicRaping
03-08-2005 11:13 PM
91ZCcivicSi
02-05-2005 07:12 PM
damn_import_culture
12-31-2004 11:58 PM
Quick Reply: DOHC VTEC head swap
