civic wont start
Old 12-09-2006, 12:15 PM
koleslaw's Avatar
Default civic wont start
Ok so I just finished putting my civic back togather, and it wont start. it is getting spark, fuel, and has good compression. The motor just cranks. I have checked all the wire connections, and cleaned all of the grounds. Please help!!!
Old 12-09-2006, 12:41 PM
JandMmotorsports's Avatar
Default Re: civic wont start (koleslaw)
hows the ign timing and valve timing?
N_A_is_best's Avatar
Default Re: civic wont start (JandMmotorsports)
r u sure the fuel pump is priming i would jumper the main relay and try it
Old 12-09-2006, 12:46 PM
koleslaw's Avatar
Default Re: civic wont start (N_A_is_best)
The valve timing is good, and so is the ign timing. The fuel pump kicks on.
Old 12-09-2006, 01:11 PM
Redline130's Avatar
Are the sparkplug wires in the correct order?
Old 12-09-2006, 02:23 PM
koleslaw's Avatar
Default Re: civic wont start (Redline130)
yes the spark plug wires are in the correct locations, and the tps and map sensors are in the right locations. I also replaced the fuel filter recently.
Old 12-09-2006, 02:28 PM
project midnight's Avatar
what motor is it? When I put my d15b1 back together I lined up the timing marks and thought I had it right but it would just crank and crank and not start, so I had to screw with the timing till I got it right and the car finally started.
Old 12-09-2006, 02:33 PM
koleslaw's Avatar
Default Re: civic wont start (more hp)
It is a mini-me. D16A6 block with a D16Y8 head. I am running OBD1.
Old 12-09-2006, 02:34 PM
did you just do the swap?
Old 12-09-2006, 02:36 PM
koleslaw's Avatar
yes about 2 months ago and I haven't been able to get it started.
Old 12-09-2006, 02:43 PM
well if the timing is all good then I have no other ideas except for if the motor is getting fuel or if it is getting spark which you already said was good so or if the wiring may have some problems.
Old 12-09-2006, 04:42 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koleslaw &raquo;</TD></TR><TR><TD CLASS="quote">It is a mini-me. D16A6 block with a D16Y8 head. I am running OBD1.</TD></TR></TABLE>
What ecu are you using and what distributor are you using?
Old 12-10-2006, 06:15 AM
koleslaw's Avatar
P28 with a Z6 dizzy
Old 12-10-2006, 11:01 AM
koleslaw's Avatar
help!!!!
Old 12-10-2006, 12:36 PM
Crx Jimmy's Avatar
what injectors are you using do you still have the resistor box? do you smell raw fuel out the tailpipe when you try cranking it? if you dont try spraying some starter fluid in the intake, if it runs for a second you have a fuel/injector problem
Old 12-10-2006, 01:25 PM
koleslaw's Avatar
Default Re: civic wont start (Crx Jimmy)
I am using the resistor box with the obd0 injectors. I can smell raw fuel out the tailpipe, and I have tried using starter fluid, but nothing?
Old 12-10-2006, 01:27 PM
koleslaw's Avatar
would the fact that my intake manifold gasket is leaking very badly cause it to not start?
1991hb's Avatar
I did a Y8 mini-me swap back in may and I had the same problem. The head ended up being bad...I had no compression in one of the cylinders. I ended up having to get a different head and now it works great.
Old 12-10-2006, 01:28 PM
koleslaw's Avatar
Default Re: (1991hb)
No the compression was 200 in every cylinder.
Old 12-10-2006, 01:29 PM
1991hb's Avatar
I'm not sure if you using OBD0 injectors having anything to do with it since you are running OBD1...sorry man
Old 12-10-2006, 02:11 PM
BIG RICH's Avatar
Are you sure the wiring was done correctly? You did say its getting spark right? if you tried starting fluid it should have fired, even if it just off right after, it should have ran long enough to burn up the starting fluid. I would check the timing again. thats where I would start. whats the year/trim level of the car it is in?
Old 12-10-2006, 02:29 PM
koleslaw's Avatar
Default Re: (BIG RICH)
It is a 90 si hatch. The timing is correct, I have checked it atleast 5 times already. The wiring should be correct because I had a honda technician look over it after I put it togather. When I asked him why it wouldn't start he was stumped.
Old 12-10-2006, 03:04 PM
Rywire's Avatar
Default Re: (koleslaw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koleslaw &raquo;</TD></TR><TR><TD CLASS="quote">I had a honda technician look over it after I put it togather. When I asked him why it wouldn't start he was stumped.</TD></TR></TABLE>
WOW, lol... Who did the wiring? Try another dizzy, and check that wiring
Old 12-10-2006, 07:35 PM
koleslaw's Avatar
Default Re: (droppedcrxsi)
I tried my friends dizzy from his rex (he was running the same set up), and had the same results. I am using a conversion harness off of my friends rex.
Old 12-11-2006, 12:54 PM
koleslaw's Avatar
bump!!!!
Quick Reply: civic wont start
