Civic stalling
Old 09-11-2010, 09:00 PM
bobdude495's Avatar
Default Civic stalling
I have a 1990 honda civic that randomly stalls. The engine shudders, makes a popping noise if my rpms go too high, and I have no idea what the problem is.
Old 09-12-2010, 04:58 PM
christiancivic's Avatar
Default Re: Civic stalling
I'm having about the same problem as you brother. My 91 hatch base has a dpfi d15. Has a high power msd ign system, header back exhaust with no cat (i bought it that way), and a cool air intake. If i try to run up over 3400 rpm it stalls out like i let off the gas and at about 3000 rpm i can give it gass again. Replaced the fuel filter and pump and still, same thing. Injectors, dizzy, pump and filter are good. SO WTF IS WRONG. I havent checked the TPS but have been told I have to take it in to get checked? ECU is throwing out 8 and 16, but dont think its right. Any help is greatly appriciated.
Old 09-12-2010, 06:17 PM
Former User's Avatar
Test the igniter unit inside the distributor. Any CEL codes?
Old 09-12-2010, 06:18 PM
This seems like a logical place to start.
Old 09-12-2010, 06:22 PM
EMTof DEATH's Avatar
Will the first thing to do is make sure that the timing is set right. Then go from there may want to look into the codes that you r getting. They just don't show up for no reason.
Old 09-13-2010, 08:45 PM
Checked timing, its good. Checked Msd high power dizzy and blaster pack, theyre good. checked cas, its good. main relay is good and ive got plenty of fuel pressure. still stumped. any more thoughts?
Old 09-13-2010, 08:47 PM
I keep getting told it could be the tps. if that is the case i might just do a mpfi and d16 swap. but to just get it to run right would be great.
Old 09-13-2010, 09:18 PM
adamyee's Avatar
I was having a similar problem, except mine would sputter and run like crap at low rpm, and then when I got on it and brought it up to speed it would be ok. My fix was a zc swap. Haven't had this much fun in the car yet.
Graiskye
10-03-2017 11:02 AM
riteshtaylor
Honda Civic (2001 - 2005)
04-18-2017 07:52 AM
Civic120713
12-30-2009 03:20 PM
CONLESS
05-19-2005 07:38 AM
Quick Reply: Civic stalling
